Picasso使用简介及分析(11)
Picasso使用简介及分析(11)
Picasso的引用清理策略
Picasso的缓存是对请求的缓存,通过WeakReference与ReferenceQueue的联合使用来缓存请求,然后
关于ReferenceQueue请看下文的详细介绍
WeakReference与ReferenceQueue联合使用构建java高速缓存
    //1.首先通过RequestWeakReference来弱化Action的引用强度
    static class RequestWeakReference<M> extends WeakReference<M> {
      final Action action;  public RequestWeakReference(Action action, M referent, ReferenceQueue<? super M> q) {
        super(referent, q);
        this.action = action;
    //2.其次通过ReferenceQueue来存放引用
    Action(Picasso picasso, T target, Request request, int memoryPolicy, int networkPolicy,
      int errorResId, Drawable errorDrawable, String key, Object tag, boolean noFade) {
        this.target = target == null ?
            null : new RequestWeakReference<T>(this, target, picasso.referenceQueue);
    //3.通过Picasso内部的CleanupThread来清理ReferenceQueue中的引用。
    @Override
    public void run() {
      Process.setThreadPriority(THREAD_PRIORITY_BACKGROUND);
      while (true) {
       try {
        // Prior to Android 5.0, even when there is no local variable, the result from
        // remove() & obtainMessage() is kept as a stack local variable.
        // We're forcing this reference to be cleared and replaced by looping every second
        // when there is nothing to do.
        // This behavior has been tested and reproduced with heap dumps.
        RequestWeakReference<?> remove = (RequestWeakReference<?>) referenceQueue.remove(THREAD_LEAK_CLEANING_MS);
        Message message = handler.obtainMessage();
        if (remove != null) {
            message.what = REQUEST_GCED;
            message.obj = remove.action;
            handler.sendMessage(message);
        } else {
            message.recycle();
        } catch (InterruptedException e) {
           break;
        } catch (final Exception e) {
          handler.post(new Runnable() {
              @Override
              public void run() {
                  throw new RuntimeException(e);
        break;
