一个初学者烧写板子过程中遇到问题的总结心得[转帖]
*** Very Important Notes ***
1. 28F128J3A must be located at 0x08000000.
J6  : connect 2-3 pins,   J9  : connect 1-2 pins
J33 : Open,               J34 : Short
2. After programming, 28F128J3A may be located at 0x0.
J6  : connect 1-2 pins,   J9  : connect 2-3 pins
J33 : Short,              J34 : Open
Source size = 15d54h
Available Target Offset Address:
0x0,0x20000,0x40000, ..., 0x1ce0000
Input target address offset [0x?] : 0x08000000
Target base address(0x08000000) = 0x0
Target offset      (0x0)        = 0x8000000
Target size        (0x20000*n)  = 0x15d54
Identification check error !!
[root@localhost Images]#
开始以为是flash坏了,好害怕,后来才明白是JTAG接触不好.在烧写ppcboot时最好用tftp先下载,实在不行在用JTAG.
6.每次Mount上ramdisk.image后,不能umount?,主机上显示device is busy.
我的解决方法是打开 系统工具=>系统监视器,杀死最下面的fam进程就好了,我也不知道为什么,呵呵.
7.烧写ramdisk时发生这样的错误
SMDK2410 # fl 1140000 30800000 220000
start_sect=0xa,end_sect=0x1a
************erase sector 0xa***********
************erase sector 0xb***********
************erase sector 0xc***********
************erase sector 0xd***********
************erase sector 0xe***********
************erase sector 0xf***********
************erase sector 0x10***********
************erase sector 0x11***********
************erase sector 0x12***********
************erase sector 0x13***********
************erase sector 0x14***********
************erase sector 0x15***********
************erase sector 0x16***********
************erase sector 0x17***********
************erase sector 0x18***********
************erase sector 0x19***********
************erase sector 0x1a***********
----------program sector 0xa---------
----------program sector 0xb---------
Error Command Sequence!mflash_program_sector error : status read
flash not completed for error
经wpq和hn的指点知道是flash的第13个扇区坏了,可以跳过此坏扇区.flash是16M,共128个扇区,16M/128=128K,每个扇区是128k,换成16进制是20000,我的flash是0xc错了,故要跳过0xa和0xb两个扇区继续写,20000*2=40000,可以多跳几个扇区.写在11a0000中.
还有修改ppcboot重新编译,在\ppcboot-2\ppcboot-2.0.0-old\lib_arm下的armlinux.c的196行左右将0x140000改为1a0000,这里的40000和
140000都是逻辑地址,在flash中起始地址是1000000,故实际的地址分别为1040000和1140000,现在ramdisk改写在11a0000中了,呵呵.
好了,先写到这里了,希望对初学者有所帮助,小妹我还要继续下大家学习,在此对wpq和kangw表示最由衷的感谢.......~!~
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!)
