自添加组件问题
有人会在自添加组件中,头文件里面*_INSTANCE and *_INIT 宏的定义吗?我模仿IDE中UART的写法,编辑工程的时候alt_sys_init.c总是报错自添加设备名没有声明
自添加设备名为CANA 在opencores_can.h中结构体的声明 typedef struct opencores_can_dev_s { alt_dev dev; alt_u32 base; }opencores_can_dev; 宏定义为 #define OPENCORES_CAN_INSTANCE(name, device) \ static opencores_can_dev device = \ { \ { \ ALT_LLIST_ENTRY, \ name##_NAME, \ NULL, /* open */ \ NULL, /* close */ \ NULL, /* read */ \ NULL, /* write */ \ NULL, /* lseek */ \ NULL, /* fstat */ \ NULL, /* ioctl */ \ }, \ name##_BASE \ }
#define OPENCORES_CAN_INIT(name, dev) \ { \ if (name##_IRQ == ALT_IRQ_NOT_CONNECTED) \ { \ ALT_LINK_ERROR ("Error: Interrupt not connected for " #dev ". " \ "interrupt is not connected for this device."); \ } \ else \ opencores_can_init (&dev, name##_BASE); \ }
声明外部函数 extern void opencores_can_init (opencores_can_dev* dev, int base);
在opencores_can.c中定义函数暂时无操作 void opencores_can_init(opencores_can_dev* dev, int base) { }
结构编译时生成alt_sys_init.c出现 OPENCORES_CAN_INSTANCE( CANA, cana ); OPENCORES_CAN_INIT( CANA, cana ); 但是报错 **** Incremental build of configuration Debug for project can_test ****
make -s all Compiling alt_sys_init.c... In file included from system_description/alt_sys_init.c:64: /cygdrive/d/can_system/opencores_can/HAL/inc/opencores_can.h:42:33: warning: no newline at end of file system_description/alt_sys_init.c:72: warning: type defaults to `int' in declaration of `OPENCORES_CAN_INSTANCE' system_description/alt_sys_init.c:72: warning: parameter names (without types) in function declaration system_description/alt_sys_init.c:72: warning: data definition has no type or storage class system_description/alt_sys_init.c: In function `alt_sys_init': system_description/alt_sys_init.c:82: warning: implicit declaration of function `OPENCORES_CAN_INIT' system_description/alt_sys_init.c:82: error: `CANA' undeclared (first use in this function) system_description/alt_sys_init.c:82: error: (Each undeclared identifier is reported only once system_description/alt_sys_init.c:82: error: for each function it appears in.) system_description/alt_sys_init.c:82: error: `cana' undeclared (first use in this function) make[1]: *** [obj/alt_sys_init.o] Error 1 make: *** [system_project] Error 2 Build completed谢谢大家帮忙看看,急!我qq:123724607
[此贴子已经被作者于2007-1-17 13:48:01编辑过] |
