2.1 主程序代码
void CFFTConversionDlg::OnBnClickedBtncal()
this->UpdateData(TRUE);
int
nN = this->m_NumN; float
fF = this->m_NumF; float
fT = this->m_NumT; bool
bIsTimesof2 = false;
for(int i= 0;i<100;i++)
if(nN==(2 < < i))
bIsTimesof2 = true;
break;
if(!bIsTimesof2)
AfxMessageBox("N请输入一个以2为底的幂级数!");
this->GetDlgItem(IDC_EDTN)->SetFocus();
return;
COMP* x = new COMP[nN];//x(n)
COMP* X = new COMP[nN];//X(k)
initX(nN,x,fF,fT);
CButton* pRadio = (CButton*)this->GetDlgItem(IDC_RADIODFT);
if(pRadio->GetCheck())
DFT(nN,x,X);
else
FFT(nN,x,X);
char buffer[256];
COMP source = X[nN-1];
sprintf(buffer,"%f+%fi",source.real(),source.imag());
CWnd* pwnd = this->GetDlgItem(IDC_EDTRET);
pwnd->SetWindowText(buffer);
CListCtrl* pList=(CListCtrl*) this->GetDlgItem(IDC_LIST1);
CListOper oper;
oper.FillList(*pList,nN,x,X);
delete[] x;
delete[] X;
2.2 子函数代码
说明:其中COMP为复数类型
* Name FT
* Function isperse Fuliye Transformation
* Params :N -- Total count of sampling points
* X -- Input sequence
* Return :XN(k)=sum[x(n)*Pow(e,j2*Pi/N)]
* k,n:0..N-1
void DFT(int N,COMP x[],COMP XK[])
double C = (2*pi)/N;
COMP t(0,0),ret(0,0);
for(int k=0;k < N;k++)
ret = COMP(0,0);
for(int i=0;i< N;i++)
t = COMP(cos(C*k*i),-sin(C*k*i));
ret += x[i]*t;
XK[k] = ret;
* Name :FFT
* Function :Fast Fuliye Transformation
* k,n:0..N-1
void FFT(int N,COMP X[],COMP XK[])
int j=0;
COMP U=0,W=0;
COMP* A = XK;
//Adjust sequence
if(i==0)
A[0] = X[0];
else
j=GetInverse(N,j);
A[i] = X[j];
//确定级别数
for(int M=0;M< N;M++)
if((1<< M)==N)
break;
for(int L=1;L<=M;L++)//1-M级依次确定
int LE = (int)pow(2,L);//间隔
int LE1 = LE/2;//W级数,如W0,W1,W2...
W=COMP(cos(pi/LE1),-sin(pi/LE1));
U=COMP(1,0);
for(j=0;j< LE1;j++)//
i=j;
while(i< N)
int IP = i+LE1;
COMP T=A[IP]*U;
A[IP]=A[i]-T;//蝶形计算
A[i]=A[i]+T;
i+=LE;
U=U*W;//不同的W次幂
void initX(int N,COMP x[],float F,float T)
x[i] = COMP(cos(2*pi*F*T*i),0);
