GDI+ 绘制模拟钟表(3)
GDI+ 绘制模拟钟表(3)
//应用
    // CoolClockDlg.h : header file
    #if !defined(AFX_COOLCLOCKDLG_H__E6592336_D273_41DE_9520_CD85332A0F96__INCLUDED_)
    #define AFX_COOLCLOCKDLG_H__E6592336_D273_41DE_9520_CD85332A0F96__INCLUDED_
    #if _MSC_VER > 1000
    #pragma once
    #endif // _MSC_VER > 1000
    #include "ColockStatic.h"
    // CCoolClockDlg dialog
    class CCoolClockDlg : public CDialog
    // Construction
    public:
        CCoolClockDlg(CWnd* pParent = NULL);    // standard constructor
    // Dialog Data
        //{{AFX_DATA(CCoolClockDlg)
        enum { IDD = IDD_COOLCLOCK_DIALOG };
        CColockStatic m_ClockStatic;
        //}}AFX_DATA
        // ClassWizard generated virtual function overrides
        //{{AFX_VIRTUAL(CCoolClockDlg)
        protected:
        virtual void DoDataExchange(CDataExchange* pDX);    // DDX/DDV support
        //}}AFX_VIRTUAL
    // Implementation
    protected:
        HICON m_hIcon;
        // Generated message map functions
        //{{AFX_MSG(CCoolClockDlg)
        virtual BOOL OnInitDialog();
        afx_msg void OnPaint();
        afx_msg HCURSOR OnQueryDragIcon();
        afx_msg void OnSize(UINT nType, int cx, int cy);
        //}}AFX_MSG
        DECLARE_MESSAGE_MAP()
    //{{AFX_INSERT_LOCATION}}
    // Microsoft Visual C++ will insert additional declarations immediately before the previous line.
    #endif // !defined(AFX_COOLCLOCKDLG_H__E6592336_D273_41DE_9520_CD85332A0F96__INCLUDED_)
    // CoolClockDlg.cpp : implementation file
    #include "stdafx.h"
    #include "CoolClock.h"
    #include "CoolClockDlg.h"
    #ifdef _DEBUG
    #define new DEBUG_NEW
    #undef THIS_FILE
    static char THIS_FILE[] = __FILE__;
    #endif
    CCoolClockDlg::CCoolClockDlg(CWnd* pParent /*=NULL*/)
        : CDialog(CCoolClockDlg::IDD, pParent)
        //{{AFX_DATA_INIT(CCoolClockDlg)
            // NOTE: the ClassWizard will add member initialization here
        //}}AFX_DATA_INIT
        // Note that LoadIcon does not require a subsequent DestroyIcon in Win32
        m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
    void CCoolClockDlg:oDataExchange(CDataExchange* pDX)
        CDialog:oDataExchange(pDX);
        //{{AFX_DATA_MAP(CCoolClockDlg)
        DDX_Control(pDX, IDC_COOL_CLOCK, m_ClockStatic);
        //}}AFX_DATA_MAP
    BEGIN_MESSAGE_MAP(CCoolClockDlg, CDialog)
        //{{AFX_MSG_MAP(CCoolClockDlg)
        ON_WM_PAINT()
        ON_WM_QUERYDRAGICON()
        ON_WM_SIZE()
        //}}AFX_MSG_MAP
    END_MESSAGE_MAP()
    // CCoolClockDlg message handlers
    BOOL CCoolClockDlg::OnInitDialog()
        CDialog::OnInitDialog();
        // Set the icon for this dialog.  The framework does this automatically
        //  when the application's main window is not a dialog
        SetIcon(m_hIcon, TRUE);            // Set big icon
        SetIcon(m_hIcon, FALSE);        // Set small icon
        // TODO: Add extra initialization here
        return TRUE;  // return TRUE  unless you set the focus to a control
    // If you add a minimize button to your dialog, you will need the code below
    //  to draw the icon.  For MFC applications using the document/view model,
    //  this is automatically done for you by the framework.
    void CCoolClockDlg::OnPaint()
        if (IsIconic())
            CPaintDC dc(this); // device context for painting
            SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
            // Center icon in client rectangle
            int cxIcon = GetSystemMetrics(SM_CXICON);
            int cyIcon = GetSystemMetrics(SM_CYICON);
            CRect rect;
            GetClientRect(&rect);
            int x = (rect.Width() - cxIcon + 1) / 2;
            int y = (rect.Height() - cyIcon + 1) / 2;
            // Draw the icon
            dc.DrawIcon(x, y, m_hIcon);
        else
            CDialog::OnPaint();
    // The system calls this to obtain the cursor to display while the user drags
    //  the minimized window.
    HCURSOR CCoolClockDlg::OnQueryDragIcon()
        return (HCURSOR) m_hIcon;
    void CCoolClockDlg::OnSize(UINT nType, int cx, int cy)
        CDialog::OnSize(nType, cx, cy);
        // TODO: Add your message handler code here
      CRect rcClient;
      GetClientRect(&rcClient);
        if(m_ClockStatic.m_hWnd)
        m_ClockStatic.MoveWindow(&rcClient, TRUE);
