HTML5 2D 游戏开发 实现 Sprite 行为(5)组合行为
组合行为各个行为会封装特定的操作,比如跑步、移动或闪耀。也可组合行为来实现更复杂的效果;例如,在蜗牛在其平台上来回移动时,会定期射出蜗牛炸弹,如图 5 所示:
图 5. 蜗牛射击序列蜗牛射击序列是 3 种行为的组合:
  • paceBehavior
  • snailShootBehavior
  • snailBombMoveBehavior
paceBehavior 和 snailShootBehavior 与蜗牛相关联,snailBombMoveBehavior 与蜗牛炸弹相关联。当 Snail Bait 创建 sprite 时,它在 Sprite 构造函数中指定前两个行为,如清单 10 中所示:
清单 10. 创建蜗牛
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
SnailBait.prototype = {
   createSnailSprites: function () {
      var snail,
          snailArtist = new SpriteSheetArtist(this.spritesheet, this.snailCells);
      for (var i = 0; i < this.snailData.length; ++i) {
         snail = new Sprite('snail',
                            snailArtist,
                            [ this.paceBehavior,
                              this.snailShootBehavior,
                              new CycleBehavior(300,  // 300ms per image
                                                1500) // 1.5 seconds between sequences
         snail.width  = this.SNAIL_CELLS_WIDTH;
         snail.height = this.SNAIL_CELLS_HEIGHT;
         snail.velocityX = this.SNAIL_PACE_VELOCITY;
         snail.direction = this.RIGHT;
         this.snails.push(snail); // Push snail onto snails array
每隔 1.5 秒,蜗牛的 CycleBehavior 就会循环显示 sprite 表单中的图像,如图 6 所示,显示每个图像 300 毫秒,这使它看起来像蜗牛在定期张开和闭上嘴巴。蜗牛的 paceBehavior 方法使它在平台上来回移动。
图 6. 蜗牛射击序列的 Sprite 表单图像蜗牛炸弹由 armSnails() 方法创建,如清单 11 所示,Snail Bait 会在游戏开始时调用。该方法迭代游戏的蜗牛,为每个蜗牛创建一个蜗牛炸弹,为每个炸弹配备一个 snailBombMoveBehavior 行为,将对蜗牛的引用存储在蜗牛炸弹中。
清单 11. 武装蜗牛
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
   armSnails: function () {
      var snail,
          snailBombArtist = new SpriteSheetArtist(this.spritesheet, this.snailBombCells);
      for (var i=0; i < this.snails.length; ++i) {
         snail = this.snails;
         snail.bomb = new Sprite('snail bomb',
                                  snailBombArtist,
                                  [ this.snailBombMoveBehavior ]);
         snail.bomb.width  = snailBait.SNAIL_BOMB_CELLS_WIDTH;
         snail.bomb.height = snailBait.SNAIL_BOMB_CELLS_HEIGHT;
         snail.bomb.top = snail.top + snail.bomb.height/2;
         snail.bomb.left = snail.left + snail.bomb.width/2;
         snail.bomb.visible = false;
         this.sprites.push(snail.bomb);
蜗牛的 snailShootBehavior 射出蜗牛炸弹,如清单 12 所示:
清单 12. 射出蜗牛炸弹
3
4
5
6
7
8
9
10
11
12
13
14
15
   this.snailShootBehavior = { // sprite is the snail
      execute: function (sprite, time, fps) {
         var bomb = sprite.bomb;
         if (! bomb.visible && sprite.artist.cellIndex === 2) {
            bomb.left = sprite.left;
            bomb.visible = true;
基于行为的游戏对于一个基于行为的游戏,在实现了基本的架构之后,完善游戏的主要任务就是实现行为。无需担忧游戏的力学基础,比如动画、帧率、滚动背景等,要让游戏充满生机,可将大部分精力集中在实现行为上。而且因为行为可在运行时混搭,所以您可以通过组合行为快速地设计场景原型。
因为 snailShootBehavior 与蜗牛有关联,所以传递给行为的 execute() 方法的 sprite 就是蜗牛。
一个蜗牛维持着对其蜗牛炸弹的引用,所以 snailShootBehavior 通过蜗牛访问该炸弹。然后,snailShootBehavior 会检查蜗牛的当前图像是否位于 图 6 中的最右端,也就是说,检查蜗牛是否马上就会张开它的嘴巴;如果是,那么该行为会将炸弹放入蜗牛口中并显示它。
因此,射出蜗牛炸弹涉及在正确的条件下放置炸弹并让它可见。移动炸弹是 snailBombMoveBehavior 的职责,如清单 13 所示:
清单 13. 蜗牛炸弹移动行为
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
SnailBait = function () {
   this.SNAIL_BOMB_VELOCITY = 450,
   this.snailBombMoveBehavior = {
      execute: function(sprite, time, fps) {  // sprite is the bomb
         if (sprite.visible && snailBait.spriteInView(sprite)) {
            sprite.left -= snailBait.SNAIL_BOMB_VELOCITY / fps;
         if (!snailBait.spriteInView(sprite)) {
            sprite.visible = false;
只要蜗牛炸弹出现在视图中,snailBombMoveBehavior 就会以速率 snailBait.SNAIL_BOMB_VELOCITY (450) 像素/秒向左侧移动炸弹。一旦炸弹移出视图,该行为就会使炸弹变得不可见。
