[求助]请帮我看看问题出在哪?
[求助]请帮我看看问题出在哪?
请大家帮我看看下面的问题出在哪?
谢谢了!!
1.
/cygdrive/d/altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld region ram1 is full (led_clk.elf section .text). Region needs to be 2324 bytes larger.
2.
/cygdrive/d/altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld section .bss [00100860 -> 00100a73] overlaps section .text [001001c8 -> 00101913]
3.
/cygdrive/d/altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld section .rodata [00100020 -> 00100073] overlaps section .exceptions [00100020 -> 001001c7]
4.
/cygdrive/d/altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld section .rwdata [00100074 -> 0010085f] overlaps section .exceptions [00100020 -> 001001c7]
peng1117,
1。你的ram1满了,你下的程序或数据太大了。
2。后面出现了地址重叠,重设地址。有可能是上面的附带问题,你先解决ram1太大的问题。
caopengly
[此贴子已经被作者于2007-1-12 12:43:40编辑过]
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
哦,谢谢版主了!!!
