用一片DS18B20构成测温系统,测量的温度精度达到0.1度,测量的温度的范围在-20度到+100度之间,用8位数码管显示出来。
#i nclude <AT89X52.H>
#i nclude <INTRINS.h>
unsigned char code displaybit[]={0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
unsigned char code displaycode[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00,0x40};
unsigned char code dotcode[32]={0,3,6,9,12,16,19,22,
25,28,31,34,38,41,44,48,
50,53,56,59,63,66,69,72,
75,78,81,84,88,91,94,97};
unsigned char displaycount;
unsigned char displaybuf[8]={16,16,16,16,16,16,16,16};
unsigned char timecount;
unsigned char readdata[8];
sbit DQ=P3^7;
bit sflag;
bit resetpulse(void)
unsigned char i;
DQ=0;
for(i=255;i>0;i--);
DQ=1;
for(i=60;i>0;i--);
return(DQ);
for(i=200;i>0;i--);
void writecommandtods18b20(unsigned char command)
unsigned char i;
unsigned char j;
for(i=0;i<8;i++)
if((command & 0x01)==0)
DQ=0;
for(j=35;j>0;j--);
DQ=1;
else
DQ=0;
for(j=2;j>0;j--);
DQ=1;
for(j=33;j>0;j--);
command=_cror_(command,1);
unsigned char readdatafromds18b20(void)
unsigned char i;
unsigned char j;
unsigned char temp;
temp=0;
for(i=0;i<8;i++)
temp=_cror_(temp,1);
DQ=0;
_nop_();
_nop_();
DQ=1;
for(j=10;j>0;j--);
if(DQ==1)
temp=temp | 0x80;
else
temp=temp | 0x00;
for(j=200;j>0;j--);
return(temp);
void main(void)
TMOD=0x01;
TH0=(65536-4000)/256;
TL0=(65536-4000)%256;
ET0=1;
EA=1;
while(resetpulse());
writecommandtods18b20(0xcc);
writecommandtods18b20(0x44);
TR0=1;
while(1)
void t0(void) interrupt 1 using 0
unsigned char x;
unsigned int result;
if(displaycount==2)
P0=displaycode[displaybuf[displaycount]] | 0x80;
else
P0=displaycode[displaybuf[displaycount]];
P2=displaybit[displaycount];
displaycount++;
if(displaycount==8)
displaycount=0;
timecount++;
if(timecount==150)
timecount=0;
writecommandtods18b20(0xbe);
readdata[0]=readdatafromds18b20();
readdata[1]=readdatafromds18b20();
for(x=0;x<8;x++)
displaybuf[x]=16;
sflag=0;
if((readdata[1] & 0xf8)!=0x00)
sflag=1;
readdata[1]=~readdata[1];
readdata[0]=~readdata[0];
result=readdata[0]+1;
readdata[0]=result;
if(result>255)
readdata[1]++;
readdata[1]=readdata[1]<<4;
readdata[1]=readdata[1] & 0x70;
x=readdata[0];
x=x>>4;
x=x & 0x0f;
readdata[1]=readdata[1] | x;
x=2;
result=readdata[1]; |
