基于 OpenWhisk 实时监测静态网页是否有乱码实例-2
自定义Slack Post Action将检测结果发送到Slack指定的Channel OpenWhisk Catalog自带了Slack Post Action,但是自带的Slack Post Action功能有限,不能满足本实例的需求,所以需要自定义Slack Post方法来发送检测结果到Slack Channel。自定的基本步骤如下:
- 为您的团队创建一个Slack并且配置Slack,配置好Slack之后,可以拿到类似如下的 Webhook URL:
- 用生成的 Webhook URL 和对应的Channel创建一个 Package
| $ wsk package create myCustomSlack --param url "https://hooks.slack.com/services/..." --param username Bob --param channel "#MySlackChannel"
- 需要写一个函数接收 Garbage Char Detection Action 传来的数据,然后发送到 Slack ,并用该函数来创建 post2slack Action
| $ wsk action create myCustomSlack/post2slack slackPost.js
其中内容如下: 代码清单4. SlackPost.js1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
| var request = require('request');
var utils = {
map : function(arr, func){
var res = [];
for(var i=0,len=arr.length; i<len; i++){
res.push(func(arr));
return res;
encodeStrings : function(arr){
return utils.map(arr, querystring.escape);
decodeStrings : function(arr){
return utils.map(arr, decodeURI);
* Action to post to slack
* @param {string} url - Slack webhook url
* @param {string} channel - Slack channel to post the message to
* @param {string} username - name to post to the message as
* @param {string} text - message to post
* @param {string} icon_emoji - (optional) emoji to use as the icon for the
message
* @param {string} as_user - (optional) when the token belongs to a bot,
whether to post as the bot itself
* @param {object} attachments - (Optional) message attachments
* @return {object} whisk async
function main(params){
if (checkParams(params)){
d = params.result;
console.log('Result: ', d);
for(var i=0,len=d.length; i<len; i++){
d['garbled_lines'] = utils.decodeStrings(d['garbled_lines']);
console.log('Decoded Result: ', d);
var body = {
channel: params.channel,
username: params.username || 'Simple Message Bot',
text: format(JSON.stringify(d, null, '\t'))
if (params.icon_emoji){
body.icon_emoji = params.icon_emoji;
if (params.token){
// this allows us to support /api/chat.postMessage
// e.g. users can pass params.url =
https://slack.com/api/chat.postMessage
// and params.token = \u003ctheir auth token\u003e
body.token = params.token;
} else {
// the webhook api expects a nested payload
// Notice that we need to stringify; this is due to limitations
// of the formData npm: it does not handle nested objects
console.log(body);
console.log("to: "+ params.url);
body = {
payload: JSON.stringify(body)
if (params.as_user === true){
body.as_user = true;
if (params.attachments) {
body.attachments = params.attachments;
var promise = new Promise(function(resolve, reject){
request.post({
url: params.url,
formData: body,
}, function(err, res, body) {
if (err) {
console.log('Error: ', err, body);
reject(err);
} else {
console.log('Success: ', params.text, ' successfully sent');
resolve();
return promise;
* Checks if all required params are set
function checkParams(params){
console.log('Post2Slack params: ', params);
if (params.result === undefined) {
whisk.error('No post data provided');
return false;
if (params.url === undefined) {
whisk.error('No webhook URL provided');
return false;
if (params.channel === undefined) {
whisk.error('No channel provided');
return false;
return true;
* format text to slack
function format(str){
return '\n\`\`\`'+str+'\n\`\`\`';
- 将 post2slack action 加入到 git2slack Sequence
为了调试方便,我们没有让GitHub Trigger来触发,还是先手动传入测试数据
| $ wsk action create git2slack --sequence garbageDetectionAction,myCustomSlack/post2slack
测试git2slack序列:
| $ wsk action invoke git2slack --blocking --result -p payload
输出结果如图8:
图8. 触发git2slack action结果当一切调试通过之后,我们在更新git2slack 序列,将getPushPayloadAction加入到git2slack序列,并更新git2slackRule.
通过以下命令更新git2slack序列:
| $ wsk action update git2slack –sequence getPushPayloadAction,garbageDetectAction,myCustomSlack/post2slack
通过如下命令集更新git2slackRule:
3
| $ wsk rule disable git2slackRule
$ wsk rule update git2slackRule gitTrigger git2slack
$ wsk rule enable git2slackRule
完成以上步骤之后,我们更新测试应用程序中的文档garbledUTF8-2.html,然后部署到Bluemix平台,并且push到GitHub Repository,这时我们在Slack会收到如下通知:
图9. Git仓库更新触发git2slck action图如图10,我们可以看到所有的Unicode在Slack上都显示"?".经过查看源代码,发现OpenWhisk只支持ASCII,并不支持Unicode.
图10. Unicode字符显示异常图解决方案:通过提供的方法,我们可以在OpenWhisk处理或传输Unicode之前,将Unicode进行编码,然后在发送Unicode到Slack的Action中进行解码就可以让Unicode字符正确的在Slack上显示。相应代码修改如下:
更改
3
4
| for(var i=0; i<ret.length; i++)
ret['garbled_lines'] = utils.encodeStrings(ret['garbled_lines']);
更改
3
其中,utils方法如下:
3
4
5
6
7
8
9
10
11
12
13
14
15
| var utils = {
var res = [];
return res;
更新好代码之后,需要更新Action garbageDetectionAction,myCustomSlack/post2slack, 以及git2slack sequence。然后,按照测试步骤,更新garbage-test-app某个文件,然后deploy到Bluemix,再push到GitHub Repository,可以在Slack收到正常的返回结果,如图11所示:
图11. Unicode显示正常图
