3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
| import javax.xml.stream.*;
public class XMLWriter {
// Namespaces
private static final String GARDENING = "http://com.bdaum.gardening";
private static final String XHTML = "http://www.w3.org/1999/xhtml";
public static void main(String[] args) throws XMLStreamException {
// Create an output factory
XMLOutputFactory xmlof = XMLOutputFactory.newInstance();
// Set namespace prefix defaulting for all created writers
xmlof.setProperty("javax.xml.stream.isPrefixDefaulting",Boolean.TRUE);
// Create an XML stream writer
XMLStreamWriter xmlw =
xmlof.createXMLStreamWriter(System.out);
// Write XML prologue
xmlw.writeStartDocument();
// Write a processing instruction
xmlw.writeProcessingInstruction(
"xml-stylesheet href='catalog.xsl' type='text/xsl'");
// Now start with root element
xmlw.writeStartElement("product");
// Set the namespace definitions to the root element
// Declare the default namespace in the root element
xmlw.writeDefaultNamespace(GARDENING);
// Writing a few attributes
xmlw.writeAttribute("productNumber","3923-1");
xmlw.writeAttribute("name","Nightshadow");
// Declare XHTML prefix
// xmlw.setPrefix("xhtml",XHTML);
// Different namespace for description element
xmlw.writeStartElement(XHTML,"description");
// Declare XHTML namespace in the scope of the description element
// xmlw.writeNamespace("xhtml",XHTML);
xmlw.writeCharacters(
"A tulip of almost black color. \nBlossoms in April & May");
xmlw.writeEndElement();
// Shorthand for empty elements
xmlw.writeEmptyElement("supplier");
xmlw.writeAttribute("name","Floral22");
// xmlw.writeEndElement();
// Write document end. This closes all open structures
xmlw.writeEndDocument();
// Close the writer to flush the output
xmlw.close();
