聊聊SecurityContextPersistenceFilter(2)
spring-security-web-4.2.3.RELEASE-sources.jar!/org/springframework/security/web/context/SecurityContextPersistenceFilter.java
* Populates the {@link SecurityContextHolder} with information obtained from the
* configured {@link SecurityContextRepository} prior to the request and stores it back in
* the repository once the request has completed and clearing the context holder. By
* default it uses an {@link HttpSessionSecurityContextRepository}. See this class for
* information <tt>HttpSession</tt> related configuration options.
* <p>
* This filter will only execute once per request, to resolve servlet container
* (specifically Weblogic) incompatibilities.
* <p>
* This filter MUST be executed BEFORE any authentication processing mechanisms.
* Authentication processing mechanisms (e.g. BASIC, CAS processing filters etc) expect
* the <code>SecurityContextHolder</code> to contain a valid <code>SecurityContext</code>
* by the time they execute.
* <p>
* This is essentially a refactoring of the old
* <tt>HttpSessionContextIntegrationFilter</tt> to delegate the storage issues to a
* separate strategy, allowing for more customization in the way the security context is
* maintained between requests.
* <p>
* The <tt>forceEagerSessionCreation</tt> property can be used to ensure that a session is
* always available before the filter chain executes (the default is <code>false</code>,
* as this is resource intensive and not recommended).
* @author Luke Taylor
* @since 3.0
public class SecurityContextPersistenceFilter extends GenericFilterBean {
static final String FILTER_APPLIED = "__spring_security_scpf_applied";
private SecurityContextRepository repo;
private boolean forceEagerSessionCreation = false;
public SecurityContextPersistenceFilter() {
this(new HttpSessionSecurityContextRepository());
public SecurityContextPersistenceFilter(SecurityContextRepository repo) {
this.repo = repo;
public void doFilter(ServletRequest req, ServletResponse res, FilterChain chain)
throws IOException, ServletException {
HttpServletRequest request = (HttpServletRequest) req;
HttpServletResponse response = (HttpServletResponse) res;
if (request.getAttribute(FILTER_APPLIED) != null) {
// ensure that filter is only applied once per request
chain.doFilter(request, response);
return;
final boolean debug = logger.isDebugEnabled();
request.setAttribute(FILTER_APPLIED, Boolean.TRUE);
if (forceEagerSessionCreation) {
HttpSession session = request.getSession();
if (debug && session.isNew()) {
logger.debug("Eagerly created session: " + session.getId());
HttpRequestResponseHolder holder = new HttpRequestResponseHolder(request,
response);
SecurityContext contextBeforeChainExecution = repo.loadContext(holder);
try {
SecurityContextHolder.setContext(contextBeforeChainExecution);
chain.doFilter(holder.getRequest(), holder.getResponse());
finally {
SecurityContext contextAfterChainExecution = SecurityContextHolder
.getContext();
// Crucial removal of SecurityContextHolder contents - do this before anything
// else.
SecurityContextHolder.clearContext();
repo.saveContext(contextAfterChainExecution, holder.getRequest(),
request.removeAttribute(FILTER_APPLIED);
if (debug) {
logger.debug("SecurityContextHolder now cleared, as request processing completed");
public void setForceEagerSessionCreation(boolean forceEagerSessionCreation) {
this.forceEagerSessionCreation = forceEagerSessionCreation;
复制代码
SecurityContextPersistenceFilter是承接容器的session与spring security的重要filter,主要工作是从session中获取SecurityContext,然后放到上下文中,之后的filter大多依赖这个来获取登录态。其主要是通过HttpSessionSecurityContextRepository来存取的。 |
