一个rom程序,编译时总说"std_logic_textio"denoted by prefix"IEEE"must exist in the library,请高手指教
library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_textio.all; library STD; use STD.textio.all;
------------------------ ENTITY DECLARATION ------------------------- entity mc8051_rom is
generic (c_init_file : string := "mc8051_rom.dua");
port (clk : in std_logic; -- clock signal reset : in std_logic; -- reset signal rom_data_o : out std_logic_vector(7 downto 0); -- data output rom_adr_i : in std_logic_vector(15 downto 0)); -- adresses
end mc8051_rom; architecture sim of mc8051_rom is
type rom_type is array (65535 downto 0) of bit_vector(7 downto 0); signal s_init : boolean := false;
begin
------------------------------------------------------------------------------ -- rom_read ------------------------------------------------------------------------------ p_read : process (clk, reset, rom_adr_i) variable v_loop : integer; variable v_line : line; variable v_rom_data : rom_type; file f_initfile : text is in c_init_file; begin if (not s_init) then v_loop := 0; while ((not endfile(f_initfile) and (v_loop < 65535))) loop readline(f_initfile,v_line); read(v_line,v_rom_data(v_loop)); v_loop := v_loop + 1; end loop; s_init <= true; end if; if (clk'event and (clk = '1')) then -- rising clock edge rom_data_o <= to_stdlogicvector(v_rom_data(conv_integer(unsigned(rom_adr_i)))); end if; end process p_read;
end sim;
