This document describes the virtual memory layout which the Linuxkernel uses for ARM processors. It indicates which regions arefree for platforms to use, and which are used by generic code.The ARM CPU is capable of addressing a maximum of 4GB virtual memoryspace, and this must be shared between user space processes, thekernel, and hardware devices.As the ARM architecture matures, it becomes necessary to reservecertain regions of VM space for use for new facilities; thereforethis document may reserve more VM space over time.Start End Use--------------------------------------------------------------------------ffff8000 ffffffff copy_user_page / clear_user_page use. For SA11xx and Xscale, this is used to setup a minicache mapping.ffff1000 ffff7fff Reserved. Platforms must not use this address range.ffff0000 ffff0fff CPU vector page. The CPU vectors are mapped here if the CPU supports vector relocation (control register V bit.)ffc00000 fffeffff DMA memory mapping region. Memory returned by the dma_alloc_xxx functions will be dynamically mapped here.ff000000 ffbfffff Reserved for future expansion of DMA mapping region.VMALLOC_END feffffff Free for platform use, recommended. VMALLOC_END must be aligned to a 2MB boundary.VMALLOC_START VMALLOC_END-1 vmalloc() / ioremap() space. Memory returned by vmalloc/ioremap will be dynamically placed in this region. VMALLOC_START may be based upon the value of the high_memory variable.PAGE_OFFSET high_memory-1 Kernel direct-mapped RAM region. This maps the platforms RAM, and typically maps all platform RAM in a 1:1 relationship.TASK_SIZE PAGE_OFFSET-1 Kernel module space Kernel modules inserted via insmod are placed here using dynamic mappings.00001000 TASK_SIZE-1 User space mappings Per-thread mappings are placed here via the mmap() system call.00000000 00000fff CPU vector page / null pointer trap CPUs which do not support vector remapping place their vector page here. NULL pointer dereferences by both the kernel and user space are also caught via this mapping.Please note that mappings which collide with the above areas may resultin a non-bootable kernel, or may cause the kernel to (eventually) panicat run time.Since future CPUs may impact the kernel mapping layout, user programsmust not access any memory which is not mapped inside their 0x0001000to TASK_SIZE address range. If they wish to access these areas, theymust set up their own mappings using open() and mmap(). |
