解决配置myeclipse+Jboss的一个异常问题
配置了两天jboss,早上的时候刚重新装的最新的jdk,有一瞬间好用了,后来还是不好用了,并且在Myeclipse里面出现了好多jboss服务器选项,后来改了一下jboss默认的一个配置文件,问题解决了!
异常如下:
java.lang.IllegalArgumentException: Wrong arguments. new for target java.lang.reflect.Constructor expected=[java.net.URI] actual=[java.io.File]
at org.jboss.reflect.plugins.introspection.ReflectionUtils.handleErrors(ReflectionUtils.java:395)
at org.jboss.reflect.plugins.introspection.ReflectionUtils.newInstance(ReflectionUtils.java:153)
at org.jboss.reflect.plugins.introspection.ReflectConstructorInfoImpl.newInstance(ReflectConstructorInfoImpl.java:106)
at org.jboss.joinpoint.plugins.BasicConstructorJoinPoint.dispatch(BasicConstructorJoinPoint.java:80)
at org.jboss.aop.microcontainer.integration.AOPConstructorJoinpoint.createTarget(AOPConstructorJoinpoint.java:282)
at org.jboss.aop.microcontainer.integration.AOPConstructorJoinpoint.dispatch(AOPConstructorJoinpoint.java:103)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction$JoinpointDispatchWrapper.execute(KernelControllerContextAction.java:241)
at org.jboss.kernel.plugins.dependency.ExecutionWrapper.execute(ExecutionWrapper.java:47)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchExecutionWrapper(KernelControllerContextAction.java:109)
at org.jboss.kernel.plugins.dependency.KernelControllerContextAction.dispatchJoinPoint(KernelControllerContextAction.java:70)
at org.jboss.kernel.plugins.dependency.InstantiateAction.installActionInternal(InstantiateAction.java:66)
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:54)
at org.jboss.kernel.plugins.dependency.InstallsAwareAction.installAction(InstallsAwareAction.java:42)
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:34
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631)
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:774)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:540)
at org.jboss.kernel.plugins.deployment.AbstractKernelDeployer.deployBean(AbstractKernelDeployer.java:319)
at org.jboss.kernel.plugins.deployment.AbstractKernelDeployer.deployBeans(AbstractKernelDeployer.java:297)
at org.jboss.kernel.plugins.deployment.AbstractKernelDeployer.deploy(AbstractKernelDeployer.java:130)
at org.jboss.kernel.plugins.deployment.BasicKernelDeployer.deploy(BasicKernelDeployer.java:76)
at org.jboss.bootstrap.microcontainer.TempBasicXMLDeployer.deploy(TempBasicXMLDeployer.java:91)
at org.jboss.bootstrap.microcontainer.TempBasicXMLDeployer.deploy(TempBasicXMLDeployer.java:161)
at org.jboss.bootstrap.microcontainer.ServerImpl.doStart(ServerImpl.java:13
at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:450)
at org.jboss.Main.boot(Main.java:221)
at org.jboss.Main$1.run(Main.java:556)
at java.lang.Thread.run(Thread.java:619)
Failed to boot JBoss:
java.lang.IllegalStateException: Incompletely deployed:
DEPLOYMENTS IN ERROR:
Deployment "AttachmentStore" is in error due to: java.lang.IllegalArgumentException: Wrong arguments. new for target java.lang.reflect.Constructor expected=[java.net.URI] actual=[java.io.File]
解决办法:
确定正在使用的要发布的服务器(server 目录下使用到的服务目录,如 all, default, minial, ...,这里我使用的是 default)。
进到类似目录 server/default/conf/bootstrap,打开文件 profile.xml
找到:
<bean name="AttachmentStore" class="org.jboss.system.server.profileservice.repository.AbstractAttachmentStore">
<constructor><parameter><inject bean="BootstrapProfileFactory" property="attachmentStoreRoot" /></parameter></constructor>
修改为:
<constructor><parameter class="java.io.File"><inject bean="BootstrapProfileFactory" property="attachmentStoreRoot" /></parameter></constructor>
重启 JBoss,问题解决。 |
