数据设备公司(DDC)正在推出BU-67401L低功耗双MIL-STD-1553收发器,用于航空电子设备和其他军事网络和通信应用,该收发器尺寸为7×7毫米。
BU-67401L收发器支持MIL-STD-1553A/B协议和MIL-STD-1760协议,并兼容McAir协议,以适应从任务计算机到地面车辆和商用飞机等广泛的地面和航空航天应用。
这款MIL-STD-1553收发器节省了尺寸、重量和功率(wap),功耗低,仅需3.3伏电源电压,封装完整,底部有散热器,工作温度范围为-55℃~125℃,并提供含铅和无铅制造(ROHS)两种规格。
(工业和信息化部电子科学技术情报研究所 冯园园)
原文:
Tiny MIL-STD-1553 tranceiver for avionic and military ytem introduced by DDC
February 7, 2012
Poted by John Keller
BOHEMIA, N.Y., 7 Feb. 2012. Data Device Corp. (DDC) in Bohemia, N.Y., i introducing the BU-67401L low-power dual MIL-STD-1553 tranceiver for avionic and other military networking and communication application. the device meaure 7 by 7 millimeter.
The BU-67401L tranceiver offer option for MIL-STD-1553A/B, MIL-STD-1760, and McAir compatibility to fit a wide range of ground and aeropace application from miion computer and diplay to ground vehicle and commercial aircraft.
The 1553 tranceiver can help ave ize, weight, and power (wap); ue low power; require only 3.3-volt power upply; i packaged with an integral, expoed heat ink on the package bottom; operate in temperature from -55 to 125 degree Celiu; and offer leaded or ROHS option.
www.taijiyundong.comwww.51rsqweixiu.comwww.haie-ktwx.com |
