Redis使用建议规范(2)
Redis使用建议规范(2)
对于必须要存储的大文本数据一定要压缩后存储
对于大文本【超过500字节】写入到Redis时,一定要压缩后存储!大文本数据存入Redis,除了带来极大的内存占用外,在访问量高时,很容易就会将网卡流量占满,进而造成整个服务器上的所有服务不可用,并引发雪崩效应,造成各个系统瘫痪!
    public Boolean setBigValue(final byte[] key, final byte[] value, final long liveTime){
            return redisTemplate.execute(new RedisCallback<Boolean>() {
                public Boolean doInRedis(RedisConnection connection) throws DataAccessException {
                    byte[] compressedBytes = CompressUtil.compress(value);
                    connection.set(key, compressedBytes);
                    if (liveTime > 0) {
                        connection.expire(key, liveTime);
                    return Boolean.TRUE;
压缩方式可参考
    public class CompressUtil {
        private static final Inflater infl = new Inflater();
        private static final Deflater defl = new Deflater();
        private CompressUtil(){
        public static byte[] uncompress(byte[] inputByte) throws IOException {
            int len = 0;
            infl.setInput(inputByte);
            ByteArrayOutputStream bos = new ByteArrayOutputStream();
            byte[] outByte = new byte[1024];
            try {
                while (!infl.finished()) {
                    len = infl.inflate(outByte);
                    if (len == 0) {
                        break;
                    bos.write(outByte, 0, len);
                infl.end();
            } catch (Exception e) {
            } finally {
                bos.close();
            return bos.toByteArray();
        public static byte[] compress(byte[] inputByte) throws IOException {
            int len = 0;
            defl.setInput(inputByte);
            defl.finish();
            byte[] outputByte = new byte[1024];
            try {
                while (!defl.finished()) {
                    len = defl.deflate(outputByte);
                    bos.write(outputByte, 0, len);
                defl.end();
            } finally {
                bos.close();
