public class CartItem implements Serializable {
private static final long serialVersionUID = 8388627124326126637L;
private Product product;
private int quantity;
public CartItem(Product product, int quantity) {
this.product = product;
this.quantity = quantity;
public int getTotalPrice() {
return this.quantity * this.product.getPrice();
public void increaseQuantity() {
this.quantity++;
/*省略getter和setter*/
除去相应的属性外, CartItem 可根据商品的数量算出该商品的总价格( getTotalPrice ),也可通过 increaseQuantity 增加商品数量。
Cart 是购物车的实现类,其同样要实现 java.io.Serializable 接口,但它没有像 ProductService 一样成为由 Spring IoC 容器管理的 Bean ,每个客户的购物车是不同的,因此不能使用 Spring IoC 容器默认的 Singleton 模式。见清单 30:
清单 30 Cart 类
private static final long serialVersionUID = 7901330827203016310L;
private Map<Integer, CartItem> map = new HashMap<Integer, CartItem>();
public List<CartItem> getItems() {
return new ArrayList<CartItem>(map.values());
public void addItem(Product product) {
int id = product.getId();
CartItem item = map.get(id);
if (item != null)
item.increaseQuantity();
else
map.put(id, new CartItem(product, 1));
int total = 0;
for (CartItem item : map.values())
total += item.getProduct().getPrice() * item.getQuantity();
return total;
