3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
| //Entry (红黑树节点的定义)
static final class Entry<K,V> implements Map.Entry<K,V> {
K key;
V value;
Entry<K,V> left;//左子节点
Entry<K,V> right;//右子节点
Entry<K,V> parent;//父节点
boolean color = BLACK;//颜色,指向该节点的链接的颜色
* Make a new cell with given key, value, and parent, and with
* {@code null} child links, and BLACK color.
Entry(K key, V value, Entry<K,V> parent) {
this.key = key;
this.value = value;
this.parent = parent;
* Returns the key.
* @return the key
public K getKey() {
return key;
* Returns the value associated with the key.
* @return the value associated with the key
public V getValue() {
return value;
* Replaces the value currently associated with the key with the given
* value.
* @return the value associated with the key before this method was
* called
public V setValue(V value) {
V oldValue = this.value;
this.value = value;
return oldValue;
public boolean equals(Object o) {
if (!(o instanceof Map.Entry))
return false;
Map.Entry<?,?> e = (Map.Entry<?,?>)o;
//Key 和 Value都要 equals
return valEquals(key,e.getKey()) && valEquals(value,e.getValue());
//哈希值的计算,Key和Value的哈希值进行位异或
public int hashCode() {
int keyHash = (key==null ? 0 : key.hashCode());
int valueHash = (value==null ? 0 : value.hashCode());
return keyHash ^ valueHash;
public String toString() {
return key + "=" + value;
