[求助]Linker Error: symbol too far way for a R_56800E_WORD16 relocation
我用codewarrior 8.2 来编译从freescale网站上下载下来的“56F8300Bootloader”,编译可以通过,但出现了linkerror,错误显示如下: Link Error : Symbol F_vector_begin_addr referenced from address 0x000401A8 in section .text of file bootloader.c is too far away for a R_56800E_WORD16 relocation, which has a range from 0 to 131070 bytes Link Error : Symbol F_Pcode_begin_addr_in_ROM referenced from address 0x000406D2 in section .text of file bootloader.c is too far away for a R_56800E_WORD16 relocation, which has a range from 0 to 131070 bytes Link Error : Symbol F_Pcode_end_addr_in_ROM referenced from address 0x000406DE in section .text of file bootloader.c is too far away for a R_56800E_WORD16 relocation, which has a range from 0 to 131070 bytes Link failed. 但好像我同事用codewarrior 7.3来编译连接就没有出现上面的错误,不知道为什么?如果我还是想使用8.2版本的话,这个问题该如何解决 谢谢! |
