exsi速用命令和常见问题(9)
exsi速用命令和常见问题(9)
27、HA配置到90%时失败,提示:Internal AAM Error-agent could not start
故障状态:
1、第一台主机加入到Cluster没问题,但是第二台主机加入到cluster时,走到90%出错,提示如下错误:Internal AAM Errors-agent could not start
复制代码
2、在aam_config_util_addnode.log文件里有类似如下错误信息:
01.01/23/10 16:20:49 [myexit ] Failure location:
02.01/23/10 16:20:49 [myexit ] function main::myexit called from line 2199
03.01/23/10 16:20:49 [myexit ] function main::start_agent called from line 1168
04.01/23/10 16:20:49 [myexit ] function main::add_aam_node called from line 171
05.01/23/10 16:20:49 [myexit ] VMwareresult=failure
故障分析:
这种故障一般和UDP 8043端口无法访问有一定关系;
解决方案:
确保UDP 8043端口畅通无阻,比如:
执行如下命令:
tcpdump -i vswif0 -s 900 -n udp port 8043 -w ${主机名}.pcap
