exsi速用命令和常见问题(13)
exsi速用命令和常见问题(13)
31、为主机应用Host Profiles提示compliance错误
故障状态:
为主机应用Host Profiles失败,提示如下错误:
01.Specification state absent from host: device ‘<datastore>’ state needs to be set to ‘on’
02.Host state doesn’t match specification: device ‘<datastore>’ needs to be reset
03.Specification state absent from host: device ‘<datastore>’ Path Selection Policy needs to be set to ‘VMW_PSP_FIXED’
04.Host state doesn’t match specification: device ‘<datastore>’ Path Selection Policy needs to be set to default for claiming SATP
故障分析:
这是由于PSA组件导致的;
解决方案:
1、右击Host Profiles后点击Enable/Disable Profiles配置选项;
2、展开“Storage Configuration”选项,展开“Pluggable Storage Architecture”这个uxanxiang;
3、去掉“PSA Device Configuration”;
4、展开“Native Muti-Pathing(NMP)”这个选项后,接着展开“PSP and SATP configuration for NMP devi”选项;
5、去掉“PSP configuration for”这个选项后点击OK即可。
