3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
| root@klausk:/tmp/a# fdisk -l
Disk /dev/hda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 * 1 1623 13036716 7 HPFS/NTFS
/dev/hda2 1624 2103 3855600 8e Linux LVM
/dev/hda3 2104 2740 5116702+ 83 Linux
/dev/hda4 3000 9729 54058725 5 Extended
/dev/hda5 9569 9729 1293232+ 82 Linux swap / Solaris
/dev/hda6 3000 4274 10241374+ 83 Linux
/dev/hda7 4275 5549 10241406 83 Linux
/dev/hda8 5550 6824 10241406 83 Linux
/dev/hda9 6825 8099 10241406 83 Linux
/dev/hda10 8100 9568 11799711 8e Linux LVM
Partition table entries are not in disk order
root@klausk:/tmp/a#
