破解MODELSIM SE?
破解MODELSIM SE?
怎么样可以破解MODELSIM SE?
先下载破解,然后里面有说明,比如
1.Install, Select Full product instllation. When asked for security key, select no. When you
see License Wizard dialog, select close because license wizard dont know our license's format.
2.Use our keygen to generate license.dat, copy it to c:\flexlm directory.
3.set enviroment string: LM_LICENSE_FILE = c:\flexlm\license.dat
4.Start Modelsim and have fun.
其中的设置环境变量比较隐晦,楼主可以在网上搜一下方法,其实很简单。
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
