初学fpga,用ise7练习自带的qst.pdf中的过程时,遇见两个问题
一是:在Analyze Post-Place & Route Static Timing process步骤,运行Analyze - Against Timing Constraints....后出现如下消息:
4 >AnalyzeTimingConstraints EXCEPTION:StaticFileParsers:Xml_Parser.c:744:1.34 - Xml_ParseException Description: line 0:An exception occurred! Type:RuntimeException, Message:The primary document entity could not be opened. Id=C:/DOCUME~1/admini/LOCALS~1/Temp/xil_2040_5.twx
ERROR:Timing:2581 - Xml Parser Exception code 0 line 0:An exception occurred! Type:RuntimeException, Message:The primary document entity could not be opened. Id=C:/DOCUME~1/admini/LOCALS~1/Temp/xil_2040_5.twx parsing file C:/DOCUME~1/admini/LOCALS~1/Temp/xil_2040_5.twx
请问这是什么意思,要如何解决?
二是在qst中写道:
1. Double-click the View/Edit Routed Design (FPGA Editor) process found in the Place & Route group of processes. Your implemented design opens in the FPGA Editor.
但是我的ise中就没有View/Edit Routed Design (FPGA Editor)这个过程,这是怎么回事?和我安装的时modelsim有没有关系?
谢谢
Poet with knife- Blood Romantic |
