beagle board dm3730添加串口4
原始代码只有串口1-3。添加串口4按照以下几个步骤:
1.修改arch/arm/mach-omap2/serial.c
添加串口4的信息
101 static struct plat_serial8250_port serial_platform_data2[] = {
102         {
103                 .mapbase        = OMAP_UART3_BASE,
104                 .irq            = 74,
105                 .flags          = UPF_BOOT_AUTOCONF,
106                 .iotype         = UPIO_MEM,
107                 .regshift       = 2,
108                 .uartclk        = OMAP24XX_BASE_BAUD * 16,
109         }, {
110                 .flags          = 0
111         }
112 };
113
114 //#ifdef CONFIG_ARCH_OMAP4
115 static struct plat_serial8250_port serial_platform_data3[] = {
116         {
117                 .mapbase        = OMAP_UART4_BASE,
118 #ifdef CONFIG_ARCH_OMAP3
119                 .irq            = 80,
120 #elif defined (CONFIG_ARCH_OMAP4)
121                 .irq            = 70,
122 #endif
123                 .flags          = UPF_BOOT_AUTOCONF,
124                 .iotype         = UPIO_MEM,
125                 .regshift       = 2,
126                 .uartclk        = OMAP24XX_BASE_BAUD * 16,
127         }, {
128                 .flags          = 0
129         }
130 };
131 //#endif
2修改arch/arm/mach-omap2/prcm-common.h
添加串口4的寄存器宏定义
383 /* CM_FCLKEN_PER, CM_ICLKEN_PER, PM_WKEN_PER shared bits */
384 #define OMAP3630_EN_UART4                               (1 << 18)
385 #define OMAP3630_EN_UART4_SHIFT                         (18)
425 /* CM_IDLEST_PER, PM_WKST_PER shared bits */
426 #define OMAP3630_ST_UART4_MASK                          (1 << 18)
427 #define OMAP3630_ST_UART4_SHIFT                         18
3.修改arch/arm/mach-omap2/clock34xx_data.c
这个文件应该是配置时钟,外设使能的
按照uart3的配置添加uart4的
2563 static struct clk uart3_fck = {
2564         .name           = "uart3_fck",
2565         .ops            = &clkops_omap2_dflt_wait,
2566         .parent         = &per_48m_fck,
2567         .enable_reg     = OMAP_CM_REGADDR(OMAP3430_PER_MOD, CM_FCLKEN),
2568         .enable_bit     = OMAP3430_EN_UART3_SHIFT,
2569         .clkdm_name     = "per_clkdm",
2570         .recalc         = &followparent_recalc,
2571 };
2572
2573 static struct clk uart4_fck = {
2574         .name           = "uart4_fck",
2575         .ops            = &clkops_omap2_dflt_wait,
2576         .parent         = &per_48m_fck,
2577         .enable_reg     = OMAP_CM_REGADDR(OMAP3430_PER_MOD, CM_FCLKEN),
2578         .enable_bit     = OMAP3630_EN_UART4_SHIFT,
2579         .clkdm_name     = "per_clkdm",
2580         .recalc         = &followparent_recalc,
2581 };
2823 static struct clk uart3_ick = {
2824         .name           = "uart3_ick",
2825         .ops            = &clkops_omap2_dflt_wait,
2826         .parent         = &per_l4_ick,
2827         .enable_reg     = OMAP_CM_REGADDR(OMAP3430_PER_MOD, CM_ICLKEN),
2828         .enable_bit     = OMAP3430_EN_UART3_SHIFT,
2829         .clkdm_name     = "per_clkdm",
2830         .recalc         = &followparent_recalc,
2831 };
2832 static struct clk uart4_ick = {
2833         .name           = "uart4_ick",
2834         .ops            = &clkops_omap2_dflt_wait,
2835         .parent         = &per_l4_ick,
2836         .enable_reg     = OMAP_CM_REGADDR(OMAP3430_PER_MOD, CM_ICLKEN),
2837         .enable_bit     = OMAP3630_EN_UART4_SHIFT,
2838         .clkdm_name     = "per_clkdm",
2839         .recalc         = &followparent_recalc,
2840 };
3451         CLK(NULL,       "per_48m_fck",  &per_48m_fck,   CK_3XXX),
3452         CLK(NULL,       "uart3_fck",    &uart3_fck,     CK_3XXX),
3453         CLK(NULL,       "uart4_fck",    &uart4_fck,     CK_3XXX),
3454         CLK(NULL,       "gpt2_fck",     &gpt2_fck,      CK_3XXX),
3475         CLK(NULL,       "wdt3_ick",     &wdt3_ick,      CK_3XXX),
3476         CLK(NULL,       "uart3_ick",    &uart3_ick,     CK_3XXX),
3477         CLK(NULL,       "uart4_ick",    &uart4_ick,     CK_3XXX),
3478         CLK(NULL,       "gpt9_ick",     &gpt9_ick,      CK_3XXX),
