使用 Dojo 开发菜单应用(4)下拉式菜单
下拉式菜单下拉式菜单指的是点击某个按钮或者菜单项时,会纵向下拉弹出的菜单。Dojo 提供的下拉式菜单一般会绑定到 dijit.form.ComboButton,dijit.form.DropDownButton 或 dijit.MenuBar Widget 上,点击这些 Widget 或 Widget 的菜单项时,会弹出下拉式菜单。以 dijit.MenuBar 为例:MenuBar Widget 是经常用到的 Widget,它模拟实现了一个典型的菜单条,横向列出若干菜单选项,当点击某个菜单项时,会下拉弹出子菜单或其他 Widget。如下图所示:
图 4. 下拉式菜单上述功能可由清单 5 实现:
清单 5. 下拉式菜单
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
<!-- 下拉式菜单,即菜单条 -->
<div id="menubar" dojoType="dijit.MenuBar">
<!-- 菜单条的菜单项 -->
<div dojoType="dijit.PopupMenuBarItem" id="file">
  <span>File</span>
  <!-- 菜单项下拉弹出子菜单 -->
  <div dojoType="dijit.Menu" id="fileMenu">
   <div dojoType="dijit.MenuItem" id="new">New</div>
   <div dojoType="dijit.MenuItem" id="open">Open</div>
   <div dojoType="dijit.MenuSeparator" id="separator"></div>
   <div dojoType="dijit.MenuItem" id="save" iconClass="dijitEditorIconSave">Save</div>
   <div dojoType="dijit.PopupMenuItem" id="saveas">
    <span>Save as</span>
    <div dojoType="dijit.Menu" id="subMenu">
     <div dojoType="dijit.MenuItem">*.txt</div>
     <div dojoType="dijit.MenuItem">*.doc</div>
    </div>
   </div>
  </div>
</div>
<div dojoType="dijit.PopupMenuBarItem" id="edit">
  <span>Edit</span>
  <div dojoType="dijit.Menu" id="editMenu">
   <div dojoType="dijit.MenuItem" iconClass="dijitEditorIcon dijitEditorIconCut"
  onClick="console.log('nothing will happen,but you can implement it!')"
  accelKey="Ctrl+X">Cut</div>
  <div dojoType="dijit.MenuItem" iconClass="dijitEditorIcon dijitEditorIconCopy"
    accelKey="Ctrl+C">Copy</div>
  <div dojoType="dijit.MenuItem" iconClass="dijitEditorIcon dijitEditorIconPaste"
    disabled="true" accelKey="Ctrl+V">Paste</div>
  </div>
</div>
<div dojoType="dijit.PopupMenuBarItem" disabled="true">
  <span>Disabled</span>
  <div dojoType="dijit.Menu">
   <div dojoType="dijit.MenuItem">If you see this,there is something wrong!</div>
  </div>
</div>
<!-- 不会执行 onclick 事件 -->
  onclick="console.log('no submenu,menu donot has any item,handle onclick event?');">
  <span>Empty</span>
  </div>
</div>
<!-- 会执行 onclick 事件 -->
<div dojoType="dijit.MenuBarItem"
  onclick="console.log('no submenu,I am MenuBarItem,handle onclick event?'); ">
  Please!
</div>
</div>
一个 dijit.MenuBar Widget 由多个 dijit.PopupMenuBarItem 或 dijit.MenuBarItem Widget 组成:
  • 示例的“File”菜单项就是由 dijit.PopupMenuBarItem Widget 实现的,当鼠标点击该菜单项时,菜单项会弹出一个子菜单或其他 Widget。同上下文菜单的 dijit.PopupMenuItem 类似,一个 dijit.PopupMenuBarItem Widget 会包含两个子节点:显示静态文本的标签(一般是写在 span 里)和一个需要显示的 Widget,该 Widget 一般是 digit.Menu Widget。
  • dijit.MenuBarItem 也是菜单条的菜单项,它不支持下拉弹出 digit.Menu 或其他 Widget。与 dijit.PopupMenuBarItem 不同,当在该 dijit.MenuBarItem Widget 单击时,会触发 onclick 函数,这点可以通过“Empty”和“Please!”菜单项得到验证:
当点击“Empty”和“Please!”菜单项时,都不会弹出下拉菜单,两者显示效果看起来一样,但实际触发的事件却不同,观察 firebug 控制台,可以发现:“Empty”菜单栏被单击后,并没有向控制台进行输出,即并没有真正执行 onclick 函数;而“Please!”菜单栏被单击后,则向控制台进行输出。
