3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| package com.nathanagood.examples.shirotest;
import org.apache.shiro.SecurityUtils;
import org.apache.shiro.authc.UsernamePasswordToken;
import org.apache.shiro.config.IniSecurityManagerFactory;
import org.apache.shiro.subject.Subject;
import org.apache.shiro.util.Factory;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class ShiroTest {
private static Logger logger = LoggerFactory.getLogger(ShiroTest.class);
public static void main(String[] args) {
// Using the IniSecurityManagerFactory, which will use the an INI file
// as the security file.
Factory<org.apache.shiro.mgt.SecurityManager> factory =
new IniSecurityManagerFactory("auth.ini");
// Setting up the SecurityManager...
org.apache.shiro.mgt.SecurityManager securityManager
= factory.getInstance();
SecurityUtils.setSecurityManager(securityManager);
Subject user = SecurityUtils.getSubject();
logger.info("User is authenticated: " + user.isAuthenticated());
