3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
| # ksh_timer -s ./mksysb -i /dev/null
----------------------Start of mksysb output--------------------------------
Creating information file (/image.data) for rootvg.
Creating list of files to back up
Backing up 56510 files........
56510 of 56510 files backed up (100%)0512-038 mksysb: Backup Completed Successfully.
----------------------End of mksysb output--------------------------------
| Function | Minimum | Maximum | Average | Total |
| or Section |iter.#| time |iter.#| time | time |#iter.| time |
|Main | |1m49.140307s|
|-set_up_environ| 1|0m00.048720s| 1|0m00.048720s|0m00.048720s| 1|0m00.048720s|
|--fail_if_wpar | 1|0m00.005507s| 1|0m00.005507s|0m00.005507s| 1|0m00.005507s|
|--getoptions | 1|0m00.012926s| 1|0m00.012926s|0m00.012926s| 1|0m00.012926s|
|-create_temp_di| 1|0m00.007239s| 1|0m00.007239s|0m00.007239s| 1|0m00.007239s|
|-if_rootvg | 1|0m00.153775s| 1|0m00.153775s|0m00.153775s| 1|0m00.153775s|
|--tddupdate | 1|0m00.070964s| 1|0m00.070964s|0m00.070964s| 1|0m00.070964s|
|--Get_Rootvg_IS| 1|0m00.042464s| 1|0m00.042464s|0m00.042464s| 1|0m00.042464s|
|--tsddupdate | 1|0m00.027835s| 1|0m00.027835s|0m00.027835s| 1|0m00.027835s|
|-if_device | 1|0m00.014855s| 1|0m00.014855s|0m00.014855s| 1|0m00.014855s|
|-if_image_data | 1|0m05.132797s| 1|0m05.132797s|0m05.132797s| 1|0m05.132797s|
|-make_backup_da| 1|0m00.350696s| 1|0m00.350696s|0m00.350696s| 1|0m00.350696s|
|--get_backup_si| 1|0m00.031814s| 1|0m00.031814s|0m00.031814s| 1|0m00.031814s|
|---get_stanza_d| 1|0m00.019862s| 1|0m00.019862s|0m00.019862s| 1|0m00.019862s|
|-run_the_exclud| 1|0m05.697004s| 1|0m05.697004s|0m05.697004s| 1|0m05.697004s|
|-backup_files| 1|1m33.029798s| 1|1m33.029798s|1m33.029798s| 1|1m33.029798s|
|--kill_pid | 1|0m02.015270s| 2|0m02.020543s|0m02.017906s| 2|0m04.035813s|
|-done_backup | 1|0m00.016388s| 1|0m00.016388s|0m00.016388s| 1|0m00.016388s|
|--kill_pid | 1|0m02.015329s| 1|0m02.015329s|0m02.015329s| 1|0m02.015329s|
|-Unaccounted | |0m04.689035s|
