4.2.11 Network device support Network device support
ARCnet devices --->
< > Dummy net driver support
< > Bonding driver support
< > EQL (serial line load balancing) support
< > Universal TUN/TAP device driver support
Ethernet (10 or 100Mbit) ---> Ethernet (10 or 100Mbit) EISA, VLB, PCI and on board controllers
<*> EtherExpressPro/100 support (eepro100, original Becker driv
er
<*> RealTek RTL-8139 PCI Fast Ethernet Adapter support
Ethernet (1000 Mbit) --->
[ ] FDDI driver support
< > PPP (point-to-point protocol) support
< > SLIP (serial line) support
Wireless LAN (non-hamradio) --->
Token Ring devices --->
[ ] Fibre Channel driver support
Wan interfaces --->
网络设备支持。主要选择网卡类型,Ethernet (10 or 100Mbit)子选项中列出
了内核可以支持的10/100M以太网卡,这里仅列出了我们选中的2种。其他子选项都
没有选。
4.2.12 Character devices Virtual terminal Support for console on virtual terminal
<*> Standard/generic (8250/16550 and compatible UARTs) serial suppo
rt Support for console on serial port
[ ] Extended dumb serial driver options
[ ] Non-standard serial port support
[ ] Unix98 PTY support
I2C support --->
Mice --->
Joysticks --->
< > QIC-02 tape support
Watchdog Cards --->
< > AMD 768 Random Number Generator support
< > Intel i8x0 Random Number Generator support
< > AMD 76x native power management (Experimental)
< > /dev/nvram support
< > Enhanced Real Time Clock Support
< > Double Talk PC internal speech card support
< > Siemens R3964 line discipline
< > Applicom intelligent fieldbus card support
Ftape, the floppy tape device driver --->
< > /dev/agpgart (AGP Support)
[ ] Direct Rendering Manager (XFree86 DRI support)
< > ACP Modem (Mwave) support
字符设备。这里主要就是选择了最前面4个跟终端和串口有关的选项,以支持虚
拟终端(远程登录要用到),支持标准串口,支持串口控制台。
4.2.13 File systems Quota support
< > Kernel automounter support
<*> Kernel automounter version 4 support (also supports v3)
<*> Reiserfs support
[ ] Enable reiserfs debug mode Stats in /proc/fs/reiserfs
<*> Ext3 journalling file system support
[ ] JBD (ext3) debugging support
<*> DOS FAT fs support
<*> MSDOS fs support
< > UMSDOS: Unix-like file system on top of standard MSDOS fs
<*> VFAT (Windows-95) fs support
< > Compressed ROM file system support Virtual memory file system support (former shm fs)
<*> ISO 9660 CDROM file system support Microsoft Joliet CDROM extensions
[ ] Transparent decompression extension
< > JFS filesystem support
< > Minix fs support
< > FreeVxFS file system support (VERITAS VxFS(TM) compatible)
< > NTFS file system support (read only)
< > OS/2 HPFS file system support /proc file system support
< > QNX4 file system support (read only)
< > ROM file system support
<*> Second extended fs support
< > System V/Xenix/V7/Coherent file system support
< > UDF file system support (read only)
< > UFS file system support (read only)
Network File Systems --->
< > Coda file system support (advanced network fs)
<*> NFS file system support Provide NFSv3 client support
[ ] Root file system on NFS
<*> NFS server support Provide NFSv3 server support
<*> SMB file system support (to mount Windows shares etc.)
[ ] Use a default NLS
< > NCP file system support (to mount NetWare volumes)
Partition Types --->
Native Language Support --->
Default NLS Option: "iso8859-1"
<*> Codepage 437 (United States, Canada)
<*> Simplified Chinese charset (CP936, GB2312)
<*> Traditional Chinese charset (Big5)
文件系统。这部分内容比较多,也很重要。首先是Quota,如果目标系统支持这
个功能,这里就要选中。然后是选择要支持的文件系统,常用的有Reiserfs,Ext3
,FAT,ISO9660,JFS等等,可以根据情况选择。/proc和ext2一定要选中。
还有Network File Systems子选项,可以选择是否支持NFS和SMB。Native Lan
guage Support子选项跟所支持的语言有关,这里没有全部列出来,我们选中了英语
和简体、繁体中文字符集。
4.2.14 Console drivers VGA text console
[ ] Video mode selection support
控制台驱动。调试的时候可以给目标系统接显示器看一下,实际系统应该可以
不选。
4.2.15 USB support
<*> Support for USB
[ ] USB verbose debug messages
--- Miscellaneous USB options Preliminary USB device filesystem
[ ] Long timeout for slow-responding devices (some MGE Ellipse UP
Se
--- USB Host Controller Drivers
<*> UHCI Alternate Driver (JE) support
<*> OHCI (Compaq, iMacs, OPTi, SiS, ALi, ...) support
--- USB Device Class drivers
< > USB MIDI support
<*> USB Mass Storage support USB Mass Storage verbose debug
[ ] Freecom USB/ATAPI Bridge support
[ ] ISD-200 USB/ATA Bridge support
[ ] Microtech CompactFlash/SmartMedia support
< > USB Modem (CDC ACM) support
< > USB Printer support
--- USB Human Interface Devices (HID)
<*> USB Human Interface Device (full HID) support
--- Input core support is needed for USB HID input layer or HID
BP
[ ] /dev/hiddev raw HID device support
--- USB Imaging devices
< > USB Kodak DC-2xx Camera support
< > USB Scanner support
< > Microtek X6USB scanner support
--- USB Multimedia devices
--- Video4Linux support is needed for USB Multimedia device suppo
rt
--- USB Network adaptors
--- USB port drivers
USB Serial Converter support --->
--- USB Miscellaneous drivers
< > Texas Instruments Graph Link USB (aka SilverLink) cable suppo
rt
< > USB LCD device support
USB支持。如果没有使用USB设备,这部分可以不选。要使用USB盘,一定要选中
USB Mass Storage support。其余很多选项我也不清楚是干什么用的。
4.3 提示
4.3.1 EXTRAVERSION
在系统中使用uname可以获得系统版本信息。比如Redhat 9:
[root@lips root]# uname -r
2.4.20-8
[root@lips root]#
返回结果表示了Redhat修订后的内核版本号。前面我们提到过,这个“-8”就
是Redhat附加在标准内核版本号后面的一个信息。
在一个运行LiPS的系统中,我们也需要确定当前使用的内核版本,通过版本信
息来知道这个内核的配置,也可以通过在标准内核版本后面附加特定的编码来实现
/usr/src/linux-2.4/Makefile中的变量EXTRAVERSION可以帮助我们达到这个目
标。下面是Makefile文件的最前面几行内容:
VERSION = 2
PATCHLEVEL = 4
SUBLEVEL = 20
EXTRAVERSION = -8
KERNELRELEASE=$(VERSION).$(PATCHLEVEL).$(SUBLEVEL)$(EXTRAVERSION)
现在KERNELRELEASE的值就是2.4.20-8。这个信息会被编译到内核中,uname工
具会从内核文件中提取出版本号。如果将Makefile做一些修改,比如,
EXTRAVERSION = -8-R2Lips
那么我们可以得到内核版本号2.4.20-8-R2Lips,表示为了创建LiPS而编译的一
个特定配置的内核,这个内核是以2.4.20-8为基础,R2Lips(Release 2 Lips)即
第二个版本。
对Makefile的修改要在编译内核之前完成。
4.3.2 .config
内核配置(make menuconfig)完成之后,会询问:
Do you wish to save your new kernel configuration?
< Yes > < No >
回答Yes,配置信息会保存在/usr/src/linux-2.4/.config文件中。注意以“.
”开头的文件是个隐藏文件,要用ls –a才看的到。.config是个文本文件,内容类
似下面:
# Loadable module support
CONFIG_MODULES=y
# CONFIG_MODVERSIONS is not set
CONFIG_KMOD=y
所以可以把这个文件保存起来,并且给文件名带上版本号,方便管理、使用。
cp .config ~/config-2.4.20-8-R2Lips
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!) |
