[求助]新人请高手看看
[求助]新人请高手看看
-- Company: njupt
-- Engineer: --
-- Create Date:    14:10:17 07/27/2007
-- Design Name: dengjingdupinlvji
-- Module Name:    shishi - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity yuanchengxv is
    Port ( chekf,finput,choice : in std_logic;
           start,clrtrig,fstd,tf : in std_logic;
           sel : in std_logic_vector(2 downto 0);
     Q1,Q2:inout std_logic_vector(31 downto 0);
           oo : out std_logic_vector(7 downto 0);
           eend : out std_logic;
           endd : out std_logic);
end yuanchengxv;
architecture art of yuanchengxv is
  component fin is
     port (chkf,fin,chois: in std_logic;
        fout: out std_logic);
  end   component ;
  component contrl is
     port (fin,start,clr,fsd:in std_logic;
 clk1,eend,clk2,clrcut std_logic);
   end  component ;
   component cnt is
     port(clk,clr:in std_logic;
      Q: out std_logic_vector(31 downto 0));
   end  component ;
   component contrl2 is
     port(fin,start,clr: in std_logic;
      endd,pul : out std_logic);
   end  component;
 component gate is
   port (clk2,fsd,cnl,pul: in std_logic;
         clkout: out std_logic);
 end component ;
 signal inclk: std_logic;
 signal fout,clrc: std_logic;
 signal clk1,clk2,clkout,pul: std_logic;
-- signal Q1,Q2: std_logic_vector(31 downto 0);
 begin
   oo<=  Q1 (7 downto 0)    when sel="000"
    else Q1 (15 downto 8)    when sel="001" else
     Q1 (23 downto 16) when sel="010" else
     Q1 (31 downto 24)   when sel="011" else
     Q2 (7 downto 0)    when sel="100" else
     Q2 (15 downto 8)    when sel="101" else
     Q2 (23 downto 16) when sel="110" else
     Q2 (31 downto 24) when sel="111" else
     "00000000";
     fenpin: process(fstd) is
       begin
      if fstd'event and fstd ='1'then
      inclk <= not inclk;
      end if;
  end process fenpin;
  fch:  fin port  map (chkf => chekf, fin => finput, chois => choice, fout => fout);
  con:  contrl port map (fin => fout,start => start, clr=>clrtrig, fsd => inclk,
                         clk1 => clk1, eend => eend,clk2 => clk2, clrc => clrc);
  cont1: cnt port map (clk => clk1,clr => clrc, Q => Q1);
  cont2: cnt port map (clk => clkout,clr => clrc, Q => Q2);
  con2: contrl2 port map (fin => fout,start => start,clr => clrc,pul => pul,endd => endd);
  gate1: gate port map  (clk2 => clk2,fsd=>inclk,cnl=>tf,pul => pul,clkout => clkout);
end art;
     library IEEE;          --计数模块
 ENTITY cnt is
    Qut std_logic_vector(31 downto 0));
 end entity cnt;
 architecture art of cnt is
    signal cnt:std_logic_vector(31 downto 0);
    begin
    process (clk,clr) is
       begin
   if  clr='1' then cnt<="00000000000000000000000000000000";
   elsif clk'event and clk='1' then cnt <= cnt+1;
   end if;
    end process;
    Q<=cnt;
  end art;
       --测频,周期控制模块
 library IEEE;
 entity contrl is
    port(fin,start,clr,fsd:in std_logic;
    clk1,eend,clk2,clrc: out std_logic);
 end contrl;
 architecture art of contrl is
     signal QQ1:std_logic;
     begin
     process(fin,clr,start) is
   begin
    if clr='1' then QQ1<='0';
    elsif fin'event and fin='1' then QQ1<=start;
    end if;
     end process;
     clrc<=clr;
     eend<=QQ1;
     clk1<=fin and QQ1;
     clk2<=fsd and QQ1;
     end art;
  library IEEE;    --测脉宽、占空比模块
  entity contrl2 is
    port(fin,start,clr:in std_logic;
         endd,pulut std_logic);
   end contrl2;
   architecture art of contrl2 is
      signal QQ: std_logic_vector(3 downto 1);
  signal A0,B0,C0,F2:std_logic;
  signal S: std_logic_vector(1 downto 0);
  begin
  S(0)<=QQ(3);
          S(1)<=QQ(2);
  process (start ,S) is
     begin
     if start='1' then F2<=fin;
      else F2<=not fin;
     end if;
     if S=2 then pul<='1' ;
      else pul<='0';
     end if;
     if S=3 then endd<='1';
      else endd<='0';
     end if;
   end process;
     A0<=F2 and QQ(1);
     B0<= not A0;
     C0<= not F2;
     process(C0,clr) is
        begin
    if clr='1' then QQ(1)<='0';
      elsif C0'event and C0='1' then QQ(1)<='1';
    end if;
     end process;
     process (A0,clr) is
       begin
   if clr='1' then QQ(2)<='0';
      elsif A0'event and A0='1' then QQ(2)<='1';
    end if;
     end process;
     process (B0,clr) is
       begin
   if clr='1' then QQ(3)<='0';
      elsif B0'event and B0='1' then QQ(3)<='1';
    end if;
     end process;
  end art;
 library IEEE;        --自校/测试频
 entity fin is
   port (chkf,fin,chois:in std_logic;
         foutut std_logic);
 end fin;
 architecture rtl of fin is
   begin
     fout<=(fin and chois) or (chkf and not chois);
  end  rtl;
 library IEEE;     --计数器二频率切换模块
  entity gate is
    port (clk2,fsd,cnl,pul:in std_logic;
    clkoutut std_logic);
  end gate;
  architecture art of gate is
    begin
      process(clk2,pul,fsd,cnl) is
    begin
     if cnl='0' then clkout<=clk2;
     else clkout<=pul and fsd;
     end if;
   end process;
   end art;
我这个程序当SEL大于3时,调不出数据,CNT2模块不计数,请高手帮我看看那
[此贴子已经被作者于2007-8-17 19:40:44编辑过]
这个代码也太长了,你说说你的问题所在啊
我不是高手
我的Q1和Q2调用的是同一个计数器cnt,但是只有Q1计数,Q2总仿真不出来,我的Q2频率比Q1高的多
上面提到的程序我以用红色标注,请大虾帮忙指点一下!
