Quantum computing in action: IBM's Q experience and the quantum shell game(4)
The mapRemember, we want to map our real-world problem onto the physical state of the quantum processor, execute the logic, and reverse the mapping back to reality.
In our shell game then, we need to:
- Pass the number of the shell selected by our user to the backend.
- Have the backend pass the data to the quantum processor in the form of QASM code that executes Grover’s algorithm.
- Retrieve those results and parse the results.
- Map the result data back into the reality (e.g. display which shell the user chose).
Phew! Hard to say, but not too hard to do. The QCode class does all the work during instantiation. Here we break it down step-by-step.
Step 1. Pass the number of the shells selected by the user to the backendWe pass a parameter to the QCode constructor indicating which shell the user chose. This guides the creation of the QASM code to properly reflect the mapping of reality onto the quantum processor’s execution environment. The QCode constructor code begins by setting up the first part of the QASM code, which simply establishes five qubit and five classical registers.
Listing 5. Set up the QASM code1
2
| //5 qubits and 5 classical registers
string preCode = "include \"qelib1.inc\";qreg q[5];creg c[5];";
Why five? Truth be told, we only need two, but we’ll use five to keep this demo in line with the Composer scores found in the on the Q experience web site.
Step 2. Have the backend pass the data to the quantum processor in the form of QASM code that executes Grover’s algorithmWe assign states to the qubits. The system builds out the QASM based on which state we are trying to represent. Remember, if the user selected shell #1, we want to set the state of our qubits to the “00” state. Shell #2 is state “01” and so forth. The switch statement handles setting up these states. The code listing below shows how to assign these states:
Listing 6. Assign the states1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
| switch (coinUnderShellNumber)
case 1: //#State=00
initCode = @"h q[1];
h q[2];
s q[1];
s q[2];
h q[2];
cx q[1],q[2];
h q[2];
s q[1];
s q[2];
break;
case 2: //#State=01
h q[2];
s q[2];
h q[2];
cx q[1],q[2];
h q[2];
s q[2];";
break;
case 3: //#State=10
h q[2];
s q[1];
h q[2];
cx q[1],q[2];
h q[2];
s q[1];";
break;
case 4: //#State=11
h q[2];
h q[2];
cx q[1],q[2];
h q[2];
break;
default:
throw new Exception("There can only be 4 shells.");
Finally, we add Grover’s algorithm to the end of this QASM code, as you can see in the following code listing:
Listing 7. Add Grover's algorithm1
2
3
4
5
6
7
8
9
10
11
12
13
14
| //everything starting at the "double Hadamard"
string postControlledNot = @"h q[1];
h q[2];
x q[1];
x q[2];
h q[2];
cx q[1], q[2];
h q[2];
x q[1];
x q[2];
h q[1];
h q[2];
measure q[1] -> c[1];
measure q[2] -> c[2];";
And we put it all together into a single string:
Listing 8. Put into a single string1
| this.qasm = preCode + initCode + postControlledNot;
And we set the number of shots to 500, so that our experiment will be run enough times to wash out the probabilities.
Listing 9. Set the number of shots |
