3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
| <?xml version="1.0" encoding="UTF-8"?>
<xs:schema elementFormDefault="qualified"
targetNamespace="http://xml.bcit.ca/PurnamaProject/2003/xui"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xui="http://xml.bcit.ca/PurnamaProject/2003/xui">
<xs:element name="XUI">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" maxOccurs="128" ref="xui:Window"/>
<xs:element minOccurs="0" maxOccurs="1" ref="xui:Resource"/>
</xs:sequence>
<xs:attribute name="id" type="xs:anyURI" use="required"/>
</xs:complexType>
</xs:element>
<xs:element name="Resource">
<xs:complexType>
<xs:sequence>
</xs:sequence>
<xs:attribute name="uri" type="xs:anyURI" use="required"/>
<xs:attribute name="class" type="xs:token" use="required"/>
<xs:attribute name="type" use="required">
<xs:simpleType>
<xs:restriction base="xs:token">
<xs:enumeration value="java"/>
<xs:enumeration value="groovy"/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
</xs:element>
<xs:element name="Window">
<xs:complexType>
<xs:sequence>
<xs:element ref="xui:GridLayout"/>
<xs:choice minOccurs="0" maxOccurs="unbounded">
<xs:element ref="xui:BasicDialog"/>
<xs:element ref="xui:OpenFileDialog"/>
<xs:element ref="xui:SaveFileDialog"/>
<xs:element ref="xui:CustomDialog"/>
<xs:element ref="xuianel"/>
<xs:element ref="xui:SplitPanel"/>
<xs:element ref="xui:TabbedPanel"/>
</xs:choice>
<xs:element minOccurs="0" maxOccurs="1" ref="xui:MenuBar"/>
</xs:sequence>
<xs:attribute name="id" type="xs:ID" use="required"/>
<xs:attribute name="x" type="xs:short" use="required"/>
<xs:attribute name="y" type="xs:short" use="required"/>
<xs:attribute name="width" type="xs:unsignedShort" use="required"/>
<xs:attribute name="height" type="xs:unsignedShort" use="required"/>
<xs:attribute name="name" type="xs:string" use="required"/>
<xs:attribute name="visible" type="xs:boolean" use="required"/>
</xs:complexType>
</xs:element>
<xs:element name="GridLayout">
<xs:complexType>
</xs:complexType>
</xs:element>
</xs:schema>
