提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/24bit DSP/PHY等常用IP cores
提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/24bit DSP/PHY等常用IP cores 1. Peripherals IP cores PCI express Solutions: - Endpoint controller/Rootmode/Switch Bridge Controller - PCIe1.0 PHY hard IP SATA Solutions: - SATA host controller - SATA device controller - SATA PHY hard IP USB2.0 Solutions: - USB2.0 OTG controller - USB2.0 host controller - USB2.0 device controller - USB2.0 PHY hard IP - USB2.0 OTG PHY hard IP - USB2.0 mobile PHY hard IP (small dieszie) USB1.0 Solutions: - USB1.0 host controller - USB1.0 device controller - USB1.0 HUB controller - USB1.0 FullSpeed/Low Speed PHY Wireless USB2.0 Solutions: - Wireless USB host controller - wireless USB device controller - wireless USB Host+device controller SDRAM memory controller Solutions -Support Mobile DDR-SDRAM (LPDDR) -Support Mobile SDR-SDRAM -Support DDR-SDRAM -Support SDR-SDRAM -Support Async-SRAM/Flash DDRn Memory controller Solutions -DDR2/DDR SDRAM controller IP -DDR3/DDR2 SDRAM controller IP -DDR2/DDR SDRAM PHY hard IP -DDR3/DDR2 SDRAM PHY hard IP Nand Flash Controller IP AMBA2.0/AMBA3.0 Peripherals IP cores (DMA/I2S/GPIO/SSI etc.) SDIO Device 2.0 Controller IP Mobile Storage host controller (Support SDIO/CEVA/MMC etc.) SD_MMC host controller IP Sony MemoryStick host controller IP Ethernet IP controller Solutions -10M/100M Ethernet MAC controller IP -10M/100M/1000M Ethernet MAC controller IP -10G Ethernet MAC controller IP Analog IO IP solutions: -DDR2 IO hard IP -DDR IO hard IP -Mobile DDR IO hard IP -LVDS IO hard IP
2. Multimedia IP cores GPU IP solutions -ATI 2D GPU IP -ATI 3D GPU IP -Img PowerVR MBX 3D GPU IP -Img PowerVR MBX-Lite 3D GPU IP Video IP Solutions -MPEG2 Decoder IP -MPEG4 Encoder IP -Video Decoder IP (Support H264/MEPG4 etc.) -Video Codec IP (Support H264/MPEG4 etc. Decoder/Encoder) Image Processing IP Solutions: -JPEG Encoder IP -JPEG Decoder IP -JPEG Codec IP -Motion JPEG Codec IP
3. CPU/MCU/DSP IP cores 24bit CoolFlux DSP soft core 8bit 8051 MCU IP PowerPC 460/440/405 soft CPU IP PowerPC PLB4 Peripherals ARC6xx/ARC7xx CPU IP MIPS4K CPU IP ARM9xx/ARM11xx CPU IP PrimeCell IP (Uart/GPIO/SSI/DC-DC converter/Audio Codec Interface etc.)
4. EDA Tools Platform 4.1 Synopsys platforms -Synthesis Solutions (Logic/Physical SYntehsis) -Power Solutions (PowerCompiler/PrimePower/PowerRail etc) -DFT Solutions (DFT Compiler/TestCompiler/ATPG etc.) -Physical Design Solutions (Layout/DRC&LVS/Extractor tools) -Mixed Signal design Solutions (Hsim/Hspice/Nanosim) -Digital Simulation (VCS/VERA/VCS-MX)
4.2 Mentor platforms -Calibre/xCalibre design platforms -DFT/ATPG/BIST Design platforms -Modelsim platforms
4.3 atrenta Design platforms -spyglass -spyglass-cdc -spyglass-dft -spyglass-power -spyglass-constraints
需要的可以email联系:jasper1949@gmail.com
microcore@sina.com
