AR模型更新(3)
AR模型更新(3)
  •    Routine mpsplot: To plot the normalized power spectum curve on the
  •    normalized frequency axis from -.5 to  +.5 .
  •         mfre : Points in frequency axis and must be the power of 2.
  •         ts   : Sample interval in seconds (real).
  •         psdr : Real array of power spectral density values.
  •         psdi : Real work array.
  •                                        in chapter 11,12
  • void mpsplot(float psdr[],float psdi[],int mfre,float ts)
  •     FILE *fp;
  •     char filename[30];
  •     int k,m2;
  •     float pmax,fs,faxis;
  •     m2=mfre/2;
  •     for(k=0;k<m2;k++){
  •         psdi[k]=psdr[k];
  •         psdr[k]=psdr[k+m2];
  •         psdr[k+m2]=psdi[k];
  •     pmax=psdr[0];
  •     for(k=1;k<mfre;k++)
  •         if(psdr[k]>pmax)
  •             pmax=psdr[k];
  •         for(k=0;k<mfre;k++) {
  •             psdr[k]=psdr[k]/pmax;
  •         if(psdr[k]<=0.0)
  •             psdr[k]=.000001;
  •     fs=1./ts;
  •     fs=fs/(float)(mfre);
  •     printf("Please input filename:\n");
  •     scanf("%s",filename);
  •     if((fp=fopen(filename,"w"))==NULL) {
  •         printf("cannot open file\n");
  •         exit(0);
  •         faxis=fs*(k-m2);
  •         fprintf(fp,"%f,%f\n",faxis,10.*log10(psdr[k]));
  •     fclose(fp);
  •     return;
  •    Routine mar1psd: To compute the power spectum by AR-model parameters.
  •    Input parameters:
  •           ip : AR model order (integer)
  •           ep   : White noise variance of model input (real)
  •           a    : Complex array of AR  parameters a(0) to a(ip)
  •    Output parameters:
  •                                         in chapter 12
  • void mar1psd(complex a[],int ip,int mfre,float *ep,float ts)
  •     static
    float psdr[4096];
  •     static
    float psdi[4096];
  •     int k;
  •     float p;
  •     for(k=0;k<=ip;k++) {
  •         psdr[k]=a[k].real;
  •         psdi[k]=a[k].imag;
  •     for(k=ip+1;k<mfre;k++) {
  •         psdr[k]=0.;
  •         psdi[k]=0.;
  •     mrelfft(psdr,psdi,mfre,-1);
  •         p=pow(psdr[k],2)+pow(psdi[k],2);
  •         psdr[k]=(*ep)*ts/p;
  •     mpsplot(psdr,psdi,mfre,ts);
  •     return;
  • * Below are examples for using @maryuwa and @mar1psd
  • #define PI            (3.1415926)
  • #define N             (1024)
  • #define AN            (10)
  • complex x[N];
  • complex r[N];
  • complex a[AN];
  • * generate random number which satify guass distribution
  • double guass_rand(void)
  •     static
    double V1, V2, S;
  •     static
    int phase = 0;
  •     double X;
  •     if ( phase == 0 ) {
  •         do {
  •             double U1 = (double)rand() / RAND_MAX;
  •             double U2 = (double)rand() / RAND_MAX;
  •             V1 = 2 * U1 - 1;
  •             V2 = 2 * U2 - 1;
  •             S = V1 * V1 + V2 * V2;
  •         } while(S >= 1 || S == 0);
  •         X = V1 * sqrt(-2 * log(S) / S);
  •     } else {
  •         X = V2 * sqrt(-2 * log(S) / S);
  •     phase = 1 - phase;
  •     return X;
  • void zx_ar_model(void)
  •     int i=0;
  •     float ep = 0;
  •     int ierror = 0;
  •      * generate x[N]
  •     srand(time(NULL));
  •     for (i=0; i<N; i++) {
  •         x.real = sin(2*PI*i/N) + guass_rand();
  •         x.imag = 0;
  •     /* Find parameters for AR model */
  •     maryuwa(x, a, r, N, AN, &ep, &ierror);
  •     /* Calculate power spectum using parameters of AR model */
  •     mar1psd(a, AN, N, &ep, 1);
  • * main.c
  • *  Created on: 2013-8-11
  • *      Author: monkeyzx
  • #include "ar_model.h"
  • int main(void)
  •     zx_ar_model();
  •     return 0;
上面的实例中给定输入信号为余弦信号,采样点数为1024个点,通过计算后的功率谱通过mpsplot函数保存到文本文件output.txt中,保存格式如下:-0.500000,-15.334630
-0.499023,-15.334833
-0.498047,-15.335444
-0.497070,-15.336456
-0.496094,-15.337864
-0.495117,-15.339655
-0.494141,-15.341816
-0.493164,-15.344331
-0.492188,-15.347179
-0.491211,-15.350342
-0.490234,-15.353794
-0.489258,-15.357505
-0.488281,-15.361453
-0.487305,-15.365603
-0.486328,-15.369924
-0.485352,-15.374381
最后借助matlab读取该文件,绘制出功率谱的图形
  • data = load('output.txt');
  • plot(data(:,1),data(:,2));
