c. 在 LOCAL STATUS bootLoad 函数之前定义函
数 bootLoadModuleInflate的原型:
#define DECOMP_BUF_SIZE (RAM_HIGH_ADRS - RAM_LOW_ADRS)
#define COMP_BUF_SIZE (DECOMP_BUF_SIZE / 3)
STATUS bootLoadModuleInflate(int zfd, FUNCPTR *pEntry)
char *imageBuf = NULL;
char *compBuf = NULL;
int fd = -1;
int rv = ERROR;
int compSize, r;
extern STATUS inflate(char *src, char *dst, int src_size);
if ((compBuf = malloc(COMP_BUF_SIZE)) == NULL)
printErr("No enough memory for image buffer
goto done;
compSize = 0;
while ((r = read(zfd, compBuf + compSize, COMP_BUF_SIZE - compSize)) > 0)
compSize += r;
if (r < 0)
printErr("Read failed: errno = %d
", errnoGet());
goto done;
if (compSize == COMP_BUF_SIZE)
printErr("Compressed image too large
goto done;
printErr("Uncompressing %d bytes... ", compSize);
if ((imageBuf = malloc(DECOMP_BUF_SIZE)) == NULL)
printErr("Not enough memory for decompression buffer
goto done;
if ((r = inflate(compBuf, imageBuf, compSize)) < 0)
printErr("
Uncompress failed
goto done;
printErr("
Loading image... ");
memDrv();
memDevCreate("mem:", imageBuf, DECOMP_BUF_SIZE);
if ((fd = open("mem:0", O_RDONLY, 0)) < 0)
printErr("
Cannot open memory device.
goto done;
if (bootLoadModule(fd, pEntry) != OK)
printErr("
Error loading: errno = %d
", errnoGet());
goto done;
printErr("
rv = OK;
done:
if (fd >= 0)
close(fd);
if (imageBuf)
free(imageBuf);
if (compBuf)
free(compBuf);
return rv;
d. 如果加载不成功,应读懂上一段代码,调整 RAM_HIGH_ADRS 和 RAM_LOW_ADRS的大小。
7 修改 config.h中的启动参数,比如启动设备为tffs=0,0(0,0),文件名为/tffs0/VxWorks.z等等,重新制作bootrom,并写入flash。 |
