[求助]mc9s12dp256的脉冲累加器PACTL中的时钟??
16-Bit Pulse Accumulator Control Register (PACTL)
0 |
  AEN |
  AMOD |
  EDGE |
CLK1 |
CLK0 |
  AOVI |
  AI |
PAEN— Pulse Accumulator A System Enable
PAMOD— Pulse Accumulator Mode
PEDGE— Pulse Accumulator Edge Control
PAMOD |
PEDGE |
Pin Action |
0 |
0 |
Falling edge |
0 |
1 |
Rising edge |
1 |
0 |
Div. by 64 clock enabled with pin high level |
1 |
1 |
Div. by 64 clock enabled with pin low level |
If the timer is not active (TEN = 0 in TSCR), there is no divide-by-64 since the ¸64 clock is generated by the timer prescaler.
CLK1 |
CLK0 |
Clock Source |
0 |
0 |
Use timer prescaler clock as timer counter clock |
0 |
1 |
Use PACLK as input to timer counter clock |
1 |
0 |
Use PACLK/256 as timer counter clock frequency |
1 |
1 |
Use PACLK/65536 as timer counter clock frequency |
请问:PACLK时钟与Div. by 64 clock 时钟是什么关系,还有它们与总线时钟又是什么关系??
Div. by 64 clock的时钟,是不是总线时钟除64??
先谢谢了!! |
正在使用MC9S12DP256和MC9S12C32,学习MC9S12UF32...... 下一步MC9S12NE64... |
你看一下《S12ECT_16B8CV1.pdf》的Figure 4-4,就会很明白了。Div.by 64 clock就是总线时钟除以64;PACLK是PACA的参考时钟,它的时钟源由PAMOD和PEDGE这两位来选择,即Table 3-5介绍的那样。 |
