nios下载后的问题
nios下载后的问题
点Programmer后提示:
File d:/experimentboard/nopain/niossmall_time_limited.sof contains one or more time_limited megafuntion time expires.Refer to the messages
window for evaluation time details.  点确定,下载完sof文件后,出现了如图所示的提示:click concel to stop using opencore plus ip点击concel后,试验箱中不在进行程序的运行。问题出在那里呢?是license的问题么?如何解决啊?
还有前面提到的双永管脚绑定的问题:我用的Altera 的cyclone ep1c6q240c8,将其
24号管脚及37号管脚与PIO输出绑定后,进行编译时,出现如下提示:
Info: Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices.
        Info: Device EP1C12Q240C8 is compatible
Error: Can't place node ~nCSO~ in location PAD_20 because location already occupied by node display[2]
Error: Can't place node ~ASDO~ in location PAD_30 because location already occupied by node display[3]
Info: No exact pin location assignment(s) for 4 pins of 27 total pins
        Info: Pin altera_reserved_tdo not assigned to an exact location on the device
        Info: Pin altera_reserved_tms not assigned to an exact location on the device
        Info: Pin altera_reserved_tck not assigned to an exact location on the device
        Info: Pin altera_reserved_tdi not assigned to an exact location on the device
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 3 errors, 0 warnings
        Error: Processing ended: Sat Apr 23 11:32:39 2005
        Error: Elapsed time: 00:00:03
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 74 warnings
我看了一下:Assignment ->devices->devices &pins->双用引脚无法进行配置。而
公司发过来的例程中却可以啊?[em27]
爱,不是激情的随口
        情,不是瞬间的感动
你用的Nios是测试版,要想让他运行,就要保证对话框不被关闭。检查你的引脚分配文件,看看引脚20和30是否同时赋给了两个不同的信号,删除一个
谢谢,斑竹,问题都一解决。方法是:第一个的LICENSE 不全,我从新处理了LICENSE。然后解决。第二个是CONFIGURE 没进行配置,无法修改双用管脚。现已经解决,共享。
爱,不是激情的随口
        情,不是瞬间的感动
[求助]to icesword : 请问你的第一个问题是怎么解决的----->
to icesword : 请问你的第一个问题是怎么解决的?license怎么修改的,能不能给我一个,我的EMAIL:    luckmanwyz@163.com
hm
告知你的软件的版本,以便能够给你一个合适的LICENSE
爱,不是激情的随口
        情,不是瞬间的感动
斑竹,你有没有QQ啊或者邮箱阿,有什么问题可以向你请教阿,我是个菜鸟,有时候出了问题不知道是软件问题,还是设置或者是自身搞错的阿???
我现在用up3板(cyclone ep1c6q240c8),有问题可以请教你啊!!!!
谢谢,斑竹!!!!!!!!!!!!!!!!!!
icesword,你好,我是用QUAR5.0,但是编译的时候也出现了你第一个问题,提示我时间限制,但是别人用这个license是可以的
我的MAIL地址是:liannunu@mail.ustc.edu.cn
能否给我发个5。0的license
有你,有我,有我们共同的努力,一定要把NIOS搞透,搞熟
已经发出,请查收!
爱,不是激情的随口
        情,不是瞬间的感动
看说明,我给你的文件中有LICENSE的使用说明
爱,不是激情的随口
        情,不是瞬间的感动
icesword,你好,我装的也是QUAR5.0,不知你可否也发一份5。0的license,非常感谢!
email: nebuladeep@163.com
这个license和原来我用的的确有不一样的,加了一些东西,现在就没有时间限制了,呵呵
谢谢拉
[求助]to icesword 我用的是QUARTUS 4.2 和NIOS II---->
to icesword 我用的是QUARTUS 4.2 和NIOS II,麻烦你给我发一个LICENSE,谢谢,我的EMAIL: luckmanwyz@163.com
hm
to icesword
我是初学者,用的是quartus2 4.0和NIOS open-core plus development kit 3.10
编译时报错为
Error: Can't find feature line for core 6AFA_1001 in current license
Error: Can't compile design containing encrypted file C:/quartus/example0/sopc_parameters_0.tdf -- current license does not allow this file to be opened
Error: Node instance the_sopc_parameters_0 instantiates undefined entity sopc_parameters_0
请问是NIOS license 的问题吗?怎么解决?
我想睡觉
可以也可以給我嗎.我都跑不起來..我用Quartus5.0 NIOSII5.0
roxette0027@yahoo.com.tw
非常謝謝..
