MP2676 Li+ Charger Protection IC With Integrated P-MOSFET
![Rank: 2](images/default/star_level2.gif)
- 来自
- 北京市
The MP2676 is a highly integrated circuit designed to provide complete Li+ battery charger protection against input over voltage, input over current and battery over voltage. The IC continuously monitors the input voltage, the input current and the battery voltage, when any of the monitored parameters exceeds its threshold, the IC immediately turns off the internal N-channel MOSFET to remove the power from the charge system before any damage occurs. Moreover, all protections also have blanking times against false triggering due to voltage spikes or current transients. The IC also features thermal shutdown protection, if the temperature exceeds 140ºC, MP2676 will turn off the internal MOSFET bridging ACIN and CHRIN. MP2676 integrates a P-channel MOSFET with the body diode reverse protection to replace the external P-channel MOSFET and blocking diode for charge function of portable devices with PMIC (Power Management IC). The above features and small package make the MP2676 an ideal part for portable application.
| FEATURES |
| DOCUMENTS | ·
No External Blocking Diode Requiring
Input Over voltage protection in 1us
Input Over Current Protection
Battery Over Voltage Protection
Integrated Charging MOSFET
Temperature monitoring and protection
High Immunity of False Triggering under Startup, Transients
