UART VHDL源程序-3
UART VHDL源程序-3
  -- Delayed Versions Of Write And Txdone Signals For Edge Detection
         Wr2 := Wr1;
     Wr1 := Write;
     Txdone1 := Txdone;
END IF ;
    END PROCESS;
Rxio:
    PROCESS (Reset, Clkx16)
VARIABLE Rd1, Rd2 : Std_logic; -- Read Input Delayed 1 And 2 Cycles
VARIABLE Rxidle1  : Std_logic; -- Rxidle Signal Delayed 1 Cycle
    BEGIN
IF Reset=''1'' THEN
     Overrun <= ''0'' ;
     Rxhold <= (OTHERS=>''0'') ;
     Parityerr <= ''0'' ;
            Framingerr <= ''0'' ;
     Rxdatardy <= ''0'' ;
     Rd1 := ''0'' ;
            Rd2 := ''0'' ;
     Rxidle1 := ''0'' ;
ELSIF Clkx16''Event AND Clkx16 = ''1'' THEN
     -- Look For Rising Edge On Idle And Update Output Registers
     IF Rxidle = ''1'' AND Rxidle1 = ''0'' THEN
         IF Rxdatardy = ''1'' THEN
          -- Overrun Error If Previous Data Is Still There
      Overrun <= ''1'';
         ELSE
      -- No Overrun Error Since Holding Register Is Empty
      Overrun <= ''0'';
      -- Update Holding Register
      Rxhold <= Rxreg;
      -- Paritygen = 1 If Parity Error
      Parityerr <= Paritygen;
      -- Framingerror If Stop Bit Is Not 1
      Framingerr <= NOT Rxstop;
      -- Signal That Data Is Ready For Reading
      Rxdatardy <= ''1'';
         END IF;
     END IF;
     Rxidle1 := Rxidle; -- Rxidle Delayed 1 Cycle For Edge Detect
     --  Clear Error And Data Registers When Data Is Read
     IF (NOT Rd2 AND Rd1) = ''1'' THEN
         Rxdatardy  <= ''0'';
         Parityerr  <= ''0'';
         Framingerr <= ''0'';
         Overrun    <= ''0'';
     END IF;
     Rd2 := Rd1; -- Edge Detect For Read
     Rd1 := Read; -- (Must Be Assigned AFTER Reference)
     IF Reset = ''1'' THEN
         Rxdatardy <= ''0'';
     END IF;
END IF ;
    END PROCESS;
    -- Drive Data Bus Only During Read
    Data <= Rxhold WHEN Read = ''1'' ELSE (OTHERS=>''Z'') ;
    -- Latch Data Bus During Write
    Txhold <= Data WHEN Write = ''1'' ELSE Txhold;
    -- Receive Data Ready Output Signal
    Rxrdy <= Rxdatardy;
    -- Transmitter Ready For Write When No Data Is In Txhold
    Txrdy <= NOT Txdatardy;
    -- Run-Time Simulation Check For Transmit Overrun
    ASSERT Write = ''0'' OR Txdatardy = ''0''
REPORT "Transmitter Overrun Error" SEVERITY WARNING;
END Exemplar;
