http://blog.sina.com.cn/s/blog_6202cb4101010cc3.html
//================================数据接收模块==========================================module uart_rx(
clk,
rst_n,
bps_start,
clk_bps,
rs232_rx,
rx_data,
rx_int,
led
inputclk; //时钟
inputrst_n; //复位
inputrs232_rx; //接收数据信号
inputclk_bps; //高电平时为接收信号中间采样点
outputbps_start; //接收信号时,波特率时钟信号置位
output [7:0] rx_data;//接收数据寄存器
outputrx_int; //接收数据中断信号,接收过程中为高
output [7:0] led;
reg [7:0] led;
regrs232_rx0,rs232_rx1,rs232_rx2,rs232_rx3;//接收数据寄存器
wire neg_rs232_rx;//表示数据线接收到下沿
always @(posedge clk or negedge rst_n)begin
if(!rst_n)begin
rs232_rx0<= 1'b0;
rs232_rx1<= 1'b0;
rs232_rx2<= 1'b0;
rs232_rx3<= 1'b0;
end
else begin
rs232_rx0<= rs232_rx;
rs232_rx1<= rs232_rx0;
rs232_rx2<= rs232_rx1;
rs232_rx3<= rs232_rx2;
end
end
assign neg_rs232_rx = rs232_rx3& rs232_rx2 & ~rs232_rx1& ~rs232_rx0;//串口传输线的下沿标志
reg bps_start_r;
reg [3:0] num;//移位次数
regrx_int; //接收中断信号
always @(posedge clk or negedgerst_n)
if(!rst_n)begin
bps_start_r<=1'bz;
rx_int<= 1'b0;
end
elseif(neg_rs232_rx) begin//
bps_start_r<=1'b1; //启动串口,准备接收数据
rx_int<=1'b1; //接收数据中断使能
end
elseif(num==4'd12) begin //接收完有用的信号,
bps_start_r<=1'b0; //接收完毕,改变波特率置位,方便下次接收
rx_int<=1'b0; //接收信号关闭
end
assign bps_start= bps_start_r;
reg [7:0]rx_data_r;//串口数据寄存器
reg [7:0]rx_temp_data;//当前数据寄存器
always @(posedgeclk or negedge rst_n)
if(!rst_n)begin
rx_temp_data<= 8'd0;
num<= 4'd0;
rx_data_r<= 8'd0;
end
elseif(rx_int) begin //接收数据处理
if(clk_bps)begin
num<= num+1'b1;
case(num)
4'd1:rx_temp_data[0] <= rs232_rx;
4'd2:rx_temp_data[1] <= rs232_rx;
4'd3:rx_temp_data[2] <= rs232_rx;
4'd4:rx_temp_data[3] <= rs232_rx;
4'd5:rx_temp_data[4] <= rs232_rx;
4'd6:rx_temp_data[5] <= rs232_rx;
4'd7:rx_temp_data[6] <= rs232_rx;
4'd8: rx_temp_data[7]<= rs232_rx;
default:;
endcase
led<= rx_temp_data;
end
num<=4'd0; //数据接收完毕
rx_data_r<= rx_temp_data;
end
end
assign rx_data =rx_data_r;
endmodule
//=================================数据发送模块=========================================
module uart_tx(
clk,
rst_n,
bps_start,
clk_bps,
rs232_tx,
rx_data,
rx_int
input clk;
input rst_n;
input clk_bps;//中间采样点
input [7:0] rx_data;//接收数据寄存器
input rx_int;//数据接收中断信号
output rs232_tx;//发送数据信号
output bps_start;//发送信号置位
regrx_int0,rx_int1,rx_int2;//信号寄存器,捕捉下降沿
wireneg_rx_int; //下降沿标志
if(!rst_n)begin
rx_int0<= 1'b0;
rx_int1<= 1'b0;
rx_int2<= 1'b0;
end
else begin
rx_int0 <= rx_int;
rx_int1 <= rx_int0;
rx_int2 <= rx_int1;
end
end
assign neg_rx_int= ~rx_int1 & rx_int2;//捕捉下沿
reg [7:0]tx_data;//待发送数据
regbps_start_r;
regtx_en;//发送信号使能,高有效
reg [3:0]num;
if(!rst_n)begin
bps_start_r<= 1'bz;
tx_en<= 1'b0;
tx_data<= 8'd0;
end
elseif(neg_rx_int) begin//当检测到下沿的时候,数据开始传送
bps_start_r<= 1'b1;
tx_data<= rx_data;
tx_en<= 1'b1;
end
elseif(num==4'd11) begin
bps_start_r<= 1'b0;
tx_en<= 1'b0;
end
end
assign bps_start = bps_start_r;
reg rs232_tx_r;
if(!rst_n)begin
num<=4'd0;
rs232_tx_r<= 1'b1;
end
else if(tx_en)begin
if(clk_bps)begin
num<=num+1'b1;
case(num)
4'd0:rs232_tx_r <= 1'b0;//起始位
4'd1:rs232_tx_r <= tx_data[0];//数据位 开始
4'd2:rs232_tx_r <= tx_data[1];
4'd3:rs232_tx_r <= tx_data[2];
4'd4:rs232_tx_r <= tx_data[3];
4'd5:rs232_tx_r <= tx_data[4];
4'd6:rs232_tx_r <= tx_data[5];
4'd7:rs232_tx_r <= tx_data[6];
4'd8:rs232_tx_r <= tx_data[7];
4'd9:rs232_tx_r <= 1'b1;//数据结束位,1位
default:rs232_tx_r <= 1'b1;
endcase
end
elseif(num==4'd11)
num<=4'd0;//发送完成,复位
end
end
assign rs232_tx =rs232_tx_r;
endmodule |
