3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
| import java.io.*;
import javax.xml.stream.*;
public class ParseByIterator {
public static void main(String[] args)
throws FileNotFoundException, XMLStreamException {
// Use reference implementation
System.setProperty(
"javax.xml.stream.XMLInputFactory",
"com.bea.xml.stream.MXParserFactory");
// Create an input factory
XMLInputFactory xmlif = XMLInputFactory.newInstance();
// Create an XML stream reader
XMLStreamReader xmlr =
xmlif.createXMLStreamReader(new FileReader("somefile.xml"));
// Loop over XML input stream and process events
while (xmlr.hasNext()) {
processEvent(xmlr);
xmlr.next();
* Process a single event
* @param xmlr - the XML stream reader
private static void processEvent(XMLStreamReader xmlr) {
switch (xmlr.getEventType()) {
case XMLStreamConstants.START_ELEMENT :
processName(xmlr);
processAttributes(xmlr);
break;
case XMLStreamConstants.END_ELEMENT :
processName(xmlr);
break;
case XMLStreamConstants.SPACE :
case XMLStreamConstants.CHARACTERS :
int start = xmlr.getTextStart();
int length = xmlr.getTextLength();
String text =
new String(xmlr.getTextCharacters(), start, length);
break;
case XMLStreamConstants.COMMENT :
case XMLStreamConstants.PROCESSING_INSTRUCTION :
if (xmlr.hasText()) {
String piOrComment = xmlr.getText();
break;
private static void processName(XMLStreamReader xmlr) {
if (xmlr.hasName()) {
String prefix = xmlr.getPrefix();
String uri = xmlr.getNamespaceURI();
String localName = xmlr.getLocalName();
private static void processAttributes(XMLStreamReader xmlr) {
for (int i = 0; i < xmlr.getAttributeCount(); i++)
processAttribute(xmlr, i);
private static void processAttribute(XMLStreamReader xmlr, int index) {
String prefix = xmlr.getAttributePrefix(index);
String namespace = xmlr.getAttributeNamespace(index);
String localName = xmlr.getAttributeName(index);
String value = xmlr.getAttributeValue(index);
