我就删了两个DCM1,2,然后好像没有改什么地方了,再生成网表的时候就出现这样的错误, ERROR:MDT - INST:mb_opb PORT:OPB_Clk CONNECTOR:sys_clk_s - E:\FPGA\system.mhs line 69 - No driver found! ERROR:MDT - INST:ilmb PORT MB_Clk CONNECTOR:sys_clk_s - E:\FPGA\system.mhs line 94 - No driver found! ERROR:MDT - INST:dlmb PORT MB_Clk CONNECTOR:sys_clk_s - E:\FPGA\system.mhs line 102 - No driver found! ERROR:MDT - INST DR_SDRAM_32Mx16 PORT evice_Clk CONNECTOR:sys_clk_s - E:\FPGA\system.mhs line 169 - No driver found! ERROR:MDT - INST:sysclk_inv PORT:Op1 CONNECTOR:sys_clk_s - E:\FPGA\system.mhs line 201 - No driver found! ERROR:MDT - INST DR_SDRAM_32Mx16 PORT evice_Clk90_in CONNECTOR:clk_90_s - E:\FPGA\system.mhs line 167 - No driver found! ERROR:MDT - INST:clk90_inv PORT:Op1 CONNECTOR:clk_90_s - E:\FPGA\system.mhs line 210 - No driver found! ERROR:MDT - INST DR_SDRAM_32Mx16 PORT DR_Clk90_in CONNECTOR:ddr_clk_90_s - E:\FPGA\system.mhs line 171 - No driver found! ERROR:MDT - INST:ddr_clk90_inv PORT:Op1 CONNECTOR:ddr_clk_90_s - E:\FPGA\system.mhs line 219 - No driver found! 全是clk出问题了,怎么解决呀
[此贴子已经被作者于2007-9-21 20:47:29编辑过] |
