<bean class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer"> <property name="systemPropertiesModeName" value="SYSTEM_PROPERTIES_MODE_OVERRIDE" /> <property name="ignoreResourceNotFound" value="true" /> <property name="locations"> <list> <value>classpath*:jedis.properties</value> </list> </property> </bean> <dubbo:application name="chatroom-cluster-provider" /> <dubbo:registry address="zookeeper://zk1:2181?backup=zk2:2181,zk3:2181" /> <dubbo:protocol name="dubbo" port="20880" /> <dubbo:service interface="org.shirdrn.dubbo.api.ChatRoomOnlineUserCounterService" version="1.0.0" cluster="failover" retries="2" timeout="1000" loadbalance="random" actives="100" executes="200" ref="chatRoomOnlineUserCounterService" protocol="dubbo" > <dubbo:method name="queryRoomUserCount" timeout="500" retries="2" loadbalance="roundrobin" actives="50" /> </dubbo:service> <bean id="chatRoomOnlineUserCounterService" class="org.shirdrn.dubbo.provider.service.ChatRoomOnlineUserCounterServiceImpl" > <property name="jedisPool" ref="jedisPool" /> </bean> <bean id="jedisPool" class="redis.clients.jedis.JedisPool" destroy-method="destroy"> <constructor-arg index="0"> <bean class="org.apache.commons.pool2.impl.GenericObjectPoolConfig"> <property name="maxTotal" value="${redis.pool.maxTotal}" /> <property name="maxIdle" value="${redis.pool.maxIdle}" /> <property name="minIdle" value="${redis.pool.minIdle}" /> <property name="maxWaitMillis" value="${redis.pool.maxWaitMillis}" /> <property name="testOnBorrow" value="${redis.pool.testOnBorrow}" /> <property name="testOnReturn" value="${redis.pool.testOnReturn}" /> <property name="testWhileIdle" value="true" /> </bean> </constructor-arg> <constructor-arg index="1" value="${redis.host}" /> <constructor-arg index="2" value="${redis.port}" /> <constructor-arg index="3" value="${redis.timeout}" /> </bean> </beans>[url=] [/url]
上面配置中,使用dubbo协议,集群容错模式为failover,服务级别负载均衡策略为random,方法级别负载均衡策略为roundrobin(它覆盖了服务级别的配置内容),其他一些配置内容可以参考Dubbo文档。我们这里是从Redis读取数据,所以使用了Redis连接池。启动服务示例代码如下所示:
[url=] [/url]
package org.shirdrn.dubbo.provider;import org.shirdrn.dubbo.provider.common.DubboServer;public class ChatRoomClusterServer { public static void main(String[] args) throws Exception { DubboServer.startServer("classpath:provider-cluster.xml"); }
上面调用了DubboServer类的静态方法startServer,如下所示:
[url=] [/url]
public static void startServer(String config) { ClassPathXmlApplicationContext context = new ClassPathXmlApplicationContext(config); try { context.start(); System.in.read(); } catch (IOException e) { e.printStackTrace(); } finally { context.close(); } }[url=] [/url]
方法中主要是初始化Spring IoC容器,全部对象都交由容器来管理。 |
