vhdl程序举例-献给和我一样刚起步的GGMM[转帖]
ljp099 该用户已被删除
最高优先级编码器
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
entity priority is
port(I : in bit_vector(7 downto 0); --inputs to be prioritised
A : out bit_vector(2 downto 0); --encoded output
GS : out bit); --group signal output
end priority;
architecture v1 of priority is
begin
process(I)
begin
GS <= '1'; --set default outputs
A <= "000";
if I(7) = '1' then
A <= "111";
elsif I(6) = '1' then
A <= "110";
elsif I(5) = '1' then
A <= "101";
elsif I(4) = '1' then
A <= "100";
elsif I(3) = '1' then
A <= "011";
elsif I(2) = '1' then
A <= "010";
elsif I(1) = '1' then
A <= "001";
elsif I(0) = '1' then
A <= "000";
else
GS <= '0';
end if;
end process;
end v1;
8位想等比较器
-- 8-bit Identity Comparator
-- uses 1993 std VHDL
library IEEE;
use IEEE.Std_logic_1164.all;
entity HCT688 is
port(Q, P : in std_logic_vector(7 downto 0);
GBAR : in std_logic; PEQ : out std_logic);
end HCT688;
architecture VER1 of HCT688 is
begin
PEQ <= '0' when ((To_X01(P) = To_X01(Q)) and (GBAR = '0')) else '1';
end VER1;
三态总线
LIBRARY IEEE;
ENTITY prebus IS
PORT(
my_in : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
sel : IN STD_LOGIC;
my_out : OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END prebus;
ARCHITECTURE cpld OF prebus IS
BEGIN
my_out <= "ZZZZZZZZ"
WHEN (sel = '1')
ELSE my_in;
END cpld;
双向总线
LIBRARY ieee;
ENTITY bidir IS
PORT(
bidir : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0);
oe, clk : IN STD_LOGIC;
inp : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
outp : OUT STD_LOGIC_VECTOR (7 DOWNTO 0));
END bidir;
ARCHITECTURE cpld OF bidir IS
SIGNAL a : STD_LOGIC_VECTOR (7 DOWNTO 0); -- DFF that stores
-- value from input.
SIGNAL b : STD_LOGIC_VECTOR (7 DOWNTO 0); -- DFF that stores
BEGIN -- feedback value.
PROCESS(clk)
BEGIN
IF clk = '1' AND clk'EVENT THEN -- Creates the flipflops
a <= inp;
outp <= b;
END IF;
END PROCESS;
PROCESS (oe, bidir) -- Behavioral representation
BEGIN -- of tri-states.
IF( oe = '0') THEN
bidir <= "ZZZZZZZZ";
b <= bidir;
ELSE
bidir <= a;
b <= bidir;
END IF;
END PROCESS;
END cpld;
多路选择器
library ieee;
use ieee.std_logic_1164.all;
entity mux is port(
a, b, c, d: in std_logic_vector(3 downto 0);
s: in std_logic_vector(1 downto 0);
x: out std_logic_vector(3 downto 0));
end mux;
architecture archmux of mux is
begin
mux4_1: process (a, b, c, d)
begin
if s = "00" then
x <= a;
elsif s = "01" then
x <= b;
elsif s = "10" then
x <= c;
else
x <= d;
end if;
end process mux4_1;
end archmux; |
