AW60 I2C_RTC 8025驱动问题
哪位朋友帮我分析下,问题在哪里呀? RTC8025的时间就是读不上来,有做过个朋友给我发一个?多谢!!!
#define ERR_OK 0 unsigned char readtime_buffer[7]; unsigned char writetime_buffer[7]={0x00,0x30,0x08,0x01,0x12,0x01,0x07};
void IIC2_Init(void); byte WriteBytesI2C(unsigned char SlaveAddress,unsigned char DateAddress, unsigned char DateNumber,unsigned char *p_date); byte ReadBytesI2C(unsigned char SlaveAddress,unsigned char DateAddress, unsigned int DateNumber,unsigned char *p_date); void Main(void) { IIC2_Init(); while(!WriteBytesI2C(0x64,0x00,0x07,writetime_buffer)==ERR_OK) _asm nop; for(;;) { while(!ReadBytesI2C(0x64,0x00,0x07,readtime_buffer)==ERR_OK) _asm nop; } }
void IIC2_Init(void) { /* IIC1A: ADDR7=1,ADDR6=0,ADDR5=1,ADDR4=0,ADDR3=0,ADDR2=1,ADDR1=0,??=0 */ setReg8(IIC1A, 0xA4); /* IIC1F: MULT1=0,MULT0=1,ICR5=0,ICR4=0,ICR3=0,ICR2=0,ICR1=0,ICR0=0 */ setReg8(IIC1F, 0x40); /* IIC1S: TCF=0,IAAS=0,BUSY=0,ARBL=1,??=0,SRW=0,IICIF=1,RXAK=0 */ setReg8(IIC1S, 0x12); /* Clear the interrupt flags */ /* IIC1C: IICEN=1 */ setReg8Bits(IIC1C, 0x80); /* IIC1C: IICEN=1,IICIE=0,MST=0,TX=1,TXAK=1,RSTA=0,??=0,??=0 */ setReg8(IIC1C, 0x98); }
byte WriteBytesI2C(unsigned char SlaveAddress,unsigned char DateAddress, unsigned char DateNumber,unsigned char *p_date) { byte Result = ERR_OK; unsigned char temp;
IIC1C_IICEN = 1; temp = IIC1S; /* Clear any pending interrupt */ IIC1S_IICIF=1;
IIC1C_MST = 0; IIC1C_TX = 1; /* Select Transmit Mode */ while(IIC1S_BUSY==1) _asm nop; /* 等待总线空闲 */ IIC1C_MST =1; /* Select Master Mode (Send Start Bit) */
for(temp=0;temp<5;temp++); /* Small delay */ IIC1D = SlaveAddress; while(IIC1S_RXAK==1) _asm nop; /* 等待从机应答 */ IIC1D = DateAddress; while(IIC1S_RXAK==1) _asm nop; /* 等待从机应答 */ for(temp=0;temp { IIC1D = *p_date++; while(IIC1S_RXAK==1) _asm nop; /* 等待从机应答 */ } IIC1C_MST = 0; /* Send Stop Bit */ return Result; }
byte ReadBytesI2C(unsigned char SlaveAddress,unsigned char DateAddress, unsigned int DateNumber,unsigned char *p_date) { byte Result = ERR_OK; unsigned char temp;
IIC1C_MST = 0; IIC1C_TX = 1; /* Select Transmit Mode */ while(IIC1S_BUSY==1) _asm nop; /* 等待总线空闲 */ IIC1C_MST = 1;
for(temp=0;temp<5;temp++); /* Small delay */ IIC1D = SlaveAddress; /* Send SlaveAddress*/ while(IIC1S_RXAK==1) _asm nop; /* 等待从机应答 */ IIC1D = DateAddress; while(IIC1S_RXAK==1) _asm nop; /* 等待从机应答 */
IIC1C_RSTA = 1; /* Send Restart bit */ for(temp=0;temp<5;temp++); /* Small delay */ IIC1D = SlaveAddress|0x01; while(IIC1S_RXAK==1) _asm nop; /* 等待从机应答 */ IIC1C_TX = 0; /* 接收状态 */ temp = IIC1D; /* 清接收状态 */ IIC1C_TXAK = 0; /* 设置接收发送应答位 */ DateNumber--; for(temp=0;temp { while(IIC1S_TCF==0) _asm nop; /* 等待接收到数据 */ *p_date++ = IIC1D; } IIC1C_TXAK = 1; /* 接收最后一个数据时主机不应答 */ while(IIC1S_TCF==0) _asm nop; /* 等待接收到数据 */ *p_date = IIC1D; IIC1C_MST = 0; /* Send Stop Bit */ return Result; }
[此贴子已经被作者于2007-1-12 12:08:40编辑过]
[此贴子已经被作者于2007-1-12 12:50:55编辑过] |
