library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
Entity kuozhan is
port( sample : IN [I]std_logic_vector[/I](7 downto 0);
clk: in std_logic;
reset: in std_logic;
enable: in std_logic;
dataout0: out [I]std_logic_vector[/I](8 downto 0)
end;
Architecture kuozhan_behav of kuozhan is
signal b0: std_logic_vector (8 downto 0);
begin
process(clk,reset)
begin
if reset='1' then
b0<=(others=>'0');
elsif clk'event and clk='1' then
if enable='1' then
if sample(7)='0' then
b0<="00" & sample(6 downto 0);
else b0<="11" & sample(6 downto 0);
end if;
end if;
end if;
end process;
dataout0<=b0;
end;
我想问一下,上面程序中定义为std_logic_vector的数据类型为什么定义成signed的类型就不行呢,定义成signed类型前仿真总是不能运行,请大虾指教。 |
