Powerint DER-227 3W通用低功耗适配器设计方案
Powerint 公司的DER-227 是采用LinkSwitch-XT 系列LNK362的3W通用低功耗适配器设计案例,输入电压从85V到265AC,3W单输出(5V/0.6A),230VAC时无负载功耗小于10mW,工作模式的效率大于70%, 超过ENERGY STAR v2, EC CoC v4 和EuP Tier 2的规范要求,满足EN55022B/CISPR22B的EMI要求,主要用于手机,PDA,数码相机,MP3/手提音频播放器等充电器/适配器,以及家用电器,工业系统和计量表电源.本文介绍了LinkSwitch-XT 系列主要特性,方框图,典型应用电路以及采用LNK362的2 W 通用输入的CV适配器电路图, 3W通用低功耗适配器详细电路图和材料清单(BOM).
LinkSwitch-XT incorporates a 700 V power MOSFET, oscillator, simple ON/OFF control scheme, a high-voltage switched current source, frequency jittering, cycle-by-cycle current limit and thermal shutdown circuitry onto a monolithic IC. The startup and operating power are derived directly from the DRAIN pin, eliminating the need for a bias winding and associated circuitry.
Product Highlights
Optimized for Lowest System Cost
? Proprietary IC trimming and transformer construction techniques enable Clampless? designs with LNK362 for lower system cost, component count and higher efficiency
? Fully integrated auto-restart for short circuit and open loop protection
? Self-biased supply – saves transformer auxiliary winding and associated bias supply components
? Frequency jittering greatly reduces EMI
? Meets HV creepage requirements between DRAIN and all other pins both on the PCB and at the package
? Lowest component count switcher solution
Features Superior to Linear/RCC
? Accurate hysteretic thermal shutdown protection –automatic recovery improves field reliability
? Universal input range allows worldwide operation
? Simple ON/OFF control, no loop compensation needed
? Eliminates bias winding – simpler, lower cost transformer
? Very low component count – higher reliability and single side printed circuit board
? Auto-restart reduces delivered power by 95% during short circuit and open loop fault conditions
? High bandwidth provides fast turn-on with no overshoot and excellent transient load response EcoSmartC Extremely Energy-Effi cient
? Easily meets all global energy efficiency regulations with no added components
? No-load consumption ?300 mW without bias winding at 265 VAC input (?50 mW with bias winding)
? ON/OFF control provides constant efficiency to very light loads – ideal for mandatory CEC regulations
Applications
? Chargers/adapters for cell/cordless phones, PDAs, digital cameras, MP3/portable audio players, and shavers
? Supplies for appliances, industrial systems, and metering
