我用的QUARTUS 和 NIOS 都是 7.2版本,开发板是DE1 的EP2C20系列 NIOS IDE 中烧程序出现 #!/bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd E:/VGA_Display/software/nios_vga_display/Debug # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x01400000 --end=0x17fffff --reset=0x1400 000 --input="nios_vga_display.elf" --output="cfi_flash.flash" --boot="E:/altea/q uartusii7.2/ip/nios2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01400000 --cable='USB-Blas ter [USB-0]' --sidp=0x01901048 --id=406684963 --timestamp=1249891810 --instance= 0 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x01901048: verified : Checksumming existing contents 00000000 : Reading existing contents 00002000 : Reading existing contents 00004000 : Reading existing contents Checksummed/read 2kB in 0.2s 00000000 ( 0%): Erasing 00002000 (33%): Erasing 00004000 (66%): Erasing Erased 24kB in 0.7s (34.2kB/s) 00000000 ( 0%): Programming 00002000 (33%): Programming 00004000 (66%): Programming Programmed 23KB +1KB in 1.2s (20.0KB/s) Device contents checksummed OK Leaving target processor paused # Creating .flash file for the datafile "$SOPC_KIT_NIOS2/bin/bin2flash" --base=0x01400000 --location=0x10 --input="nios_ vga_display.elf" --output="nios_vga_display.flash" # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01400000 --cable='USB-Blas ter [USB-0]' --sidp=0x01901048 --id=406684963 --timestamp=1249891810 --instance= 0 "nios_vga_display.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x01901048: verified : Checksumming existing contents 00000000 : Reading existing contents 00002000 : Reading existing contents 00004000 : Reading existing contents 00006000 : Reading existing contents 00008000 : Reading existing contents 0000A000 : Reading existing contents 0000C000 : Reading existing contents 0000E000 : Reading existing contents 00010000 : Reading existing contents Checksummed/read 1kB in 0.0s 00000000 ( 0%): Erasing 00002000 ( 6%): Erasing 00004000 (12%): Erasing 00006000 (18%): Erasing 00008000 (25%): Erasing 0000A000 (31%): Erasing 0000C000 (37%): Erasing 0000E000 (43%): Erasing 00010000 (50%): Erasing Erased 128kB in 3.2s (40.0kB/s) 00000000 ( 0%): Programming 00002000 ( 5%): Programming 00004000 (10%): Programming 00006000 (16%): Programming 00008000 (21%): Programming 0000A000 (26%): Programming 0000C000 (32%): Programming 0000E000 (37%): Programming 00010000 (43%): Programming Program failed at offset 15569 Leaving target processor pause 我用的QUARTUS 和 NIOS 都是 7.2版本,开发板是DE1 的EP2C20系列 求高人指点 |
