[求助]哪位大侠用过MC9S12XDT256单片机的
- 女
以前没接触过can模块,不知道can的程序如何写,研究过MC9S12XDT256单片机的各位大侠能否给一个can模块的初始化例子参考一下啊,我的邮箱是angelrandy@126.com,小女子先在此谢过了,[em23] |
- 女
- 女
这是我开发板配套程序中原函数,自己灵活的修改下就可以用了: void InitCAN0(void) { CAN0CTL0 = 0x01; /* Enter Initialization Mode * * 0b00000001 * ||||||||__ Enter Initialization Mode * |||||||___ Sleep Mode Request bit * ||||||____ Wake-Up disabled * |||||_____ Time stamping disabled * ||||______ Synchronized Status * |||_______ CAN not affected by Wait * ||________ Receiver Active Status bit * |_________ Received Frame Flag bit */ while(CAN0CTL1_INITAK!=1); // Wait for Initialization Mode acknowledge INITRQ bit = 1 CAN0CTL1 = 0x80; /* Enable MSCAN module and not LoopBack Mode * * 0b10100000 * ||||||||__ Initialization Mode Acknowledge * |||||||___ Sleep Mode Acknowledge * ||||||____ Wake-up low-pass filter disabled * |||||_____ Unimplemented * ||||______ Listen Only Mode disabled * |||_______ not Loop Back Mode enabled * ||________ Ext Osc/Xtal as Clock Source * |_________ MSCAN Module enabled */ CAN0BTR0 = 0x43; /* Synch Jump = 2 Tq clock Cycles * * 0b01000011 * ||||||||__ * |||||||___\ * ||||||____ | * |||||_____ |_ CAN Clock Prescaler = 4 * ||||______ | * |||_______/ * ||________ * |_________>- SJW = 2 */ CAN0BTR1 = 0x14; /* Set Number of samples per bit, TSEG1 and TSEG2 * bit rate=Fclk/pres v/(1+TSEG1+TSEG2)=16M/4/(1+2+5)=500kbps * 0b00010100 * ||||||||__ * |||||||___\ * ||||||____ |- TSEG1 = 5 * |||||_____/ * ||||______ * |||_______\_ TSEG2 = 2 * ||________/ * |_________ One sample per bit */ CAN0IDAC = 0x00; /* Set two 32-bit Filters * * 0b00000000 * ||||||||__ * |||||||___\_ Filter Hit Indicator * ||||||____/ * |||||_____ Unimplemented * ||||______ * |||_______>- two 32-bit Acceptance Filters * ||________ * |_________>- Unimplemented */ /* note Acceptance Filters neither Acceptance Filter is accorded with,message in receivebuffer will pass */ CAN0IDAR0 = ACC_CAN0_EX_ID_R0; // |\ 32 bit Filter 0 CAN0IDAR1 = ACC_CAN0_EX_ID_R1; // | \__ Accepts Extended Data Frame Msg CAN0IDAR2 = ACC_CAN0_EX_ID_R2; // | / with ID: CAN0_ID CAN0IDAR3 = ACC_CAN0_EX_ID_R3; // |/ CAN0IDAR4 = ACC_CAN0_EX_ID_R0; // |\ 32 bit Filter 0 CAN0IDAR5 = ACC_CAN0_EX_ID_R1; // | \__ Accepts Extended Data Frame Msg CAN0IDAR6 = ACC_CAN0_EX_ID_R2; // | / with ID: CAN0_ID CAN0IDAR7 = ACC_CAN0_EX_ID_R3; // |/ CAN0IDMR0 = MASK_CAN0_EX_ID_R0; CAN0IDMR1 = MASK_CAN0_EX_ID_R1; CAN0IDMR2 = MASK_CAN0_EX_ID_R2; CAN0IDMR3 = MASK_CAN0_EX_ID_R3; CAN0IDMR4 = MASK_CAN0_EX_ID_R0; CAN0IDMR5 = MASK_CAN0_EX_ID_R1; CAN0IDMR6 = MASK_CAN0_EX_ID_R2; CAN0IDMR7 = MASK_CAN0_EX_ID_R3;
CAN0CTL0 = 0x00; /* Exit Initialization Mode Request */ while ((CAN0CTL1&0x01)!=0); // 等待,直到MSCAN正常运行 while(!(CAN0CTL0&0x10)); // 等待,直到MSCAN与CAN总线同步 CAN0RFLG = 0xC3; /* Reset Receiver Flags * * 0b11000011 * ||||||||__ Receive Buffer Full Flag * |||||||___ Overrun Interrupt Flag * ||||||____ * |||||_____>- Transmitter Status Bits * ||||______ * |||_______>- Receiver Status Bits * ||________ CAN Status Change Interrupt Flag * |_________ Wake-Up Interrupt Flag */ CAN0RIER = 0x01; /* Enable Receive Buffer Full Interrupt * * 0b00000001 * ||||||||__ Receive Buffer Full Int enabled * |||||||___ Overrun Int disabled * ||||||____ * |||||_____>- Tx Status Change disabled * ||||______ * |||_______>- Rx Status Change disabled * ||________ Status Change Int disabled * |_________ Wake-Up Int disabled */ } |
飞思卡尔8/16/32位多功能开发板/下载器:
网站:http://www.lqist.cn,
淘宝店:http://shop36265907.taobao.com |
多谢游侠了!初始化程序已经差不多弄懂了,我用的是CAN4,但现在的问题是程序运行时CANRXFLG寄存器中的TSTAT1位总是置1,即传送错误,看了几天也不知道问题出在哪儿! |
把相应的0改为4即可,这个程序是经过我们的开发板验证的,完全可以使用! |
- 来自
- 北京
