更新下列 IP cores,需要的可以联系:
1.  Synopsys Superspeed USB3.0  Host controller soft core (AHB interface)
2.  Synopsys Superspeed USB3.0  Device controller soft core (AHB interface)
3.  Synopsys Superspeed USB3.0  Hub controller  softcore
4.  ARM1176JZF-S CPU soft IP core  (with VFP)
5.  ARM Mail55 3D graphics soft IP core
6.  ARM PL301 L2 Cache Controller IP core
7.  MIPS4K CPU soft IP core
8.  MIPS24KC CPU soft IP core
9.  AMD 2D/vector graphics soft IP core  (support OpenVG1.1 / Adobe Flash 7.0 )
10. AMD 3D graphics soft IP core (support OpenGL ES2.0)
11. Imagine Technogies SGX520 3D graphics soft IP core  (for med end products)
12. Imagine Technogies SGX535 3D graphics soft IP core  (for high end products)
13. Imagine Technogies TV encoder soft IP core ( support 720P/1080i HD encoder)
14. Zoran CVD2 TV decoder soft IP core
15. Arasan SD2.0/SDIO2.0/MMC4.0 host controller soft IP core
16. Arasna SDIO2.0 device controller soft IP core
17. Arasan Nandflash controller soft IP core
18. Sillicon Image HDMI transimiter 1.1 controller soft IP core
19. TSMC 90G 10bit 250M ADC data converter hard IP core
20. TSMC 90G eFuse OTP hard IP core
21. TSMC 90LP eFuse OTP hard IP core
22. Charted 0.18um 1.8v/5.0v eMemory (OTP) hard IP core
24. Silltera 0.18um 1.8v/5.0v eMemory (OTP) hard IP core
25. Chipieda USB2.0 High speed device controller soft IP core
26. Chipieda USB2.0 High speed single-port host controller soft IP core
27. Chipieda USB2.0 High speed OTG controller soft IP core
28. Chipieda USB2.0 High speed multi-point host controller soft IP core
29. Chipieda USB2.0 Full speed OTG device controller soft IP core
30. Chipieda WLAN AFE (8bit, 22MHz/44MHz) hard IP core (TSMC65LP)
31. Cast 1T R8051XC2 8bit soft MCU core
32. USB1.0/USB2.0 controller and PHY
33. PCIe Controller/PHY
34. SATA controller and PHY
35. DDR2/DDR, DDR2/DDR3 controller and PHY
36. Mentor SATA host /Device controller core and PHY
37. H264/MPEG4/JPEG Codec
38. H264/MPEG4/JPEG Decoder
39. 24bit CoolFlux DSP soft core
40. PowerPC 460/440/405 soft CPU IP
41. PowerPC PLB4 Peripherals
42. AMBA2.0/AMBA3.0 Peripherals IP cores
AND MORE...
EMAIL : jasper2049@gmail.com
上面那个卖IP是骗人的
我被骗过很多RMB
结果甚么都没买到
请大家千万不要上当!!
